Aircraft totally unstable and aggressive after recent firmware up...
MiguelAngel
Flight distance : 25479 ft
Hello All,
with this metod you are using for getting an old firmware would be possible to get the last beta and upload to P4 with an option of going back to the official?
best regards,
MA
2017-7-27
fans0e00ebfc
Flight distance : 477851 ft
Latest app 4.1.4 compatible with the downgraded firmware?
2017-7-27
Punchbuggy
Flight distance : 573054 ft
beeper Posted at 2017-7-27 00:10
Hi Punchbuggy
Well, that stuffs up what I was thinking. I was hoping that you upgraded from V01-02-0503 to the Beta. Also when you did the Beta testing was there a second round of testing where DJI fixed up issues that the Beta testers found? Or has DJI fixed(or thought they fixed) up the issues that the beta testers found and just released it to the public without a second round of testing? Still, doesn't answer why some people have no issues with the new firmware.
Beeper, to my knowledge there was only one beta - .0012. It went dormant for 6 months before being merged with updates from the new generation and finally released as a buggy prod release.
I've started a thread to try to find someone still with the P4 beta. It's still a better firmware than what was just released...
2017-7-27
Aardvark
Flight distance : 384432 ft
Punchbuggy Posted at 2017-7-27 01:46
How did you come off the Beta, did the latest build become visible in Assistant 2 ? Or was it pushed as a file directly to the beta testers ?
If you went back to Beta, would updating in future pose any problems.
2017-7-27
Zimmerman 61
Flight distance : 730052 ft
Duchunter Posted at 2017-7-26 07:38
Its really easy. It sounds much more involved than what it really is. You dont have to load multiple versions of the firmware. You just have to flash it a couple of times so that all the data is written. When we say "flash" it just means you select the "flash" tab again after it finishes the first time. Basically you just download the DUMLdore file and when its done click on it and an option to unzip will appear at the top of the window. You click unzip and it will ask you where you want it unzipped to. Just right click on your desktop and select "new folder" and a new folder will appear on your desktop and then you just name it what you want to call it. When you unzip DUMLdore you will select that folder you just made and it will unzip to there. Then you just go to that folder and select the second file down. Then DUMLdore will open and you will see a window with 3 tabs, "Backup", "load", and "flash". Hook up your p4 to the micro usb cable it came with and plug it in your usb. First you select "backup" and it will save your current firmware into the DUMLdore folder. You really wont need it again but its just good practice to back it up just in case. After you download the firmware file 0602 you will select "load" and it will pop up a window that asks you what file you want to load. Select the firmware file you downloaded (0602) and then select flash. It will wright it to the p4 and after its done select flash again. After it finishes your done. You only need one of the firmware files. You can use either one but most people are using 0602.
Thanks for that Duchunter that makes total sense. I will give it a go tomorrow. Thanks to yourself and the others on this forum for finding a solution. Much appreciated.
Have a good one
Zimmerman
2017-7-27
fans7f228480
Flight distance : 995259 ft
OK people I have just updated to the latest from the downgraded version on my P4, I used the Assistant 2 to do the drone as the Controller was still on the latest version from the DJI App, I have done a flight test and I have to say I have not found anything so far to be  with wrong  my P4 now, I was having issues of speed on forward and backwards and up and down, now all gone, jerky movement when in hover mode, all gone and now it seams to be performing how it should have the first time and have all the extra modes on the drone now, regards TJK.
2017-7-27
JockC
Flight distance : 459416 ft
fans7f228480 Posted at 2017-7-27 03:14
I would  be interested to hear if this also works for other owners who have downgraded. If they can downgrade and then upgrade to the latest firmware again with no instability then it may be worth a try.
2017-7-27
MiguelAngel
JockC Posted at 2017-7-27 03:17
Maybe the firm is fixed and is different even with the same version number...
Your idea is very interesting.
MA
2017-7-27
Aardvark
So it could be the firmware updating procedure that may be a bit flawed rather than the firmware. Is everybody using latest version of Assistant 2 as opposed to an older version installed sometime ago  ?
2017-7-27
pllphoto
Flight distance : 8903051 ft
I've downgraded and upgraded to the latest, still jerks like crazy.
2017-7-27
SomeoneElsesDro
Flight distance : 419669 ft
pllphoto Posted at 2017-7-27 03:33
Can I confirm without ANY IMU cal after update?
2017-7-27
fans7f228480
I did not do any IMU or compass calibrations after I updated with assistant 2 just took her out in the field and turned her on waited for her to do her thing then took off to a hover height of 3 feet and saw that she was stable for 3 or 4 mins then took her out to about 100 feet full speed and returned full speed the took her up to 120 Meters  and she sat there with no issues, brought her down and then had a fly about over the ground and done a RTH and that was fine also. Regards TJK.
2017-7-27
fans7f228480
SomeoneElsesDro Posted at 2017-7-27 03:53
2017-7-27
aguilera_br
Flight distance : 18507 ft
Brazil
Have a look at expo settings. I got mine messed up after a firmware upgrade once.
2017-7-27
Enilson Arneiro
Flight distance : 546604 ft
Brazil
The only thing I felt was that the landing is not very efficient as the 02.00.206 version ...
2017-7-27
F.KOK
Flight distance : 19109472 ft
Namibia
Aardvark Posted at 2017-7-27 03:31
Yes I have used the latest version, reinstall it again and did the update but the Drone is still unstable
2017-7-27
pllphoto
What I did at first was downgrade to 503 then to 602 then to version 2 (latest firmware) then did a calibration, flys terrible. So I redid everything again, i went to 503 again, to 602, did a calibration on 602, then updated to the latest firmware and did not do a calibration for the latest version. Still flies terribly. I put the Phantom 4 back into my case. New firmware shall be announced soon.
2017-7-27
Pokerormen
Flight distance : 243150 ft
Sweden
New firmware and has now flown about 120 minutes with a much more stable machine and with significantly better image quality. No disturbances and no fault. My phantom is purchased in Norway and is flying in Sweden. Drive with ipad mini with g4. Very pleased with the latest update and know everyone who got your machines in chaos .. Mvh Salmon fish
2017-7-27
Punchbuggy
Aardvark Posted at 2017-7-27 01:52
Hi Aa. Yup. Initially ther latest P4 release didn't appear in Assistant 2 (only the Beta for refresh), but after complaint it was referred to engineers and then it appeared for update. All of this is clearly driven by flags in our DJI account - I would guess that a 'global' flag is overridden by an 'individual' flag (for selective access to a beta, for example).
And no, I don't believe if I went back to the Beta I would be stuck there again, as I could see .106 to upgrade this time. Also, we now have the tool to put any version onto our craft (assuming availability of the .bin file), so can spoof whichever version required now.
2017-7-27
Punchbuggy
Yeah, I agree with you. I've been wondering why the update process has such variable success, and that would explain it. Of the firmware releases captured in Icer's Dumbledore collection, the only one I have real confidence in is the .602 which Duc provided from his new P4 (if I got that right, Duc). The others were captured, to my understanding, as update downloads.
Two interesting points of note from this amazing thread; firstly, each firmware release is a collection of individual controller updates applied one-by-one, as guided by the master .cfg file. Secondly, the flash process Must be done twice, as the first flash doesn't apply all individual updates on the craft. My take from the last is that the first flash may not apply drivers already existing at the same (or more recent) version level, but doing it twice is like a 'brute force' approach - desirable should the existing driver have been corrupted on download.
Personally, I'm thinking that the best approach for DJI from here is to change their whole approach to craft updates. DJI should simply make available their firmware release as a single .bin file, like their P4P+ controller, which can be downloaded with integrity checking, then applied locally. The current issues are most likely caused by corruption on downloading from highly conjested DJI servers, with further latency introduced via internet links, home WiFi, etc. I wonder what file integrity checking is done during the current DJU Assistant 2 process.
But, of course, I'm just making observations, and my conclusions could be cr@p... hehe
2017-7-27
SomeoneElsesDro
Punchbuggy Posted at 2017-7-27 15:54
Would it be possible to take the BIN files from a handful of the success stories (using Dumbledore) and treat them as the source and run a checksum to compare the integrity of their files to those of us less fortunate ??
2017-7-27
Punchbuggy
SomeoneElsesDro Posted at 2017-7-27 16:05
Sort of what I'vee been wondering SED. Perhaps some nice body with a clean flying P4 on the new release (.106) would like to backup their installation with Dumbledore and upload here so this can be done? Hallmark7, Vendex, Ercoupedriver, anyone?
2017-7-27
SomeoneElsesDro
Punchbuggy Posted at 2017-7-27 16:13
Sort of what I'vee been wondering SED. Perhaps some nice body with a clean flying P4 on the new release (.106) would like to backup their installation with Dumbledore and upload here so this can be done? Hallmark7, anyone?
Of course the other way to test, would be to flash the bird with the 'clean' version a couple of times and see how it flies. But for the purposes of understanding what is going on, it would be good to know if there are differences. Not a developer (just a tech journo) but assume it could be done bit by bit or could generate a md5sum and then compare....
2017-7-27
Mugrunty
Flight distance : 599449 ft
Sooo...What if you use the Harry potter wizard to apply the new update twice? Lol, does it fix the instability issues? I might try to unupgrade my drone this weekend so I can fly my drone.
2017-7-27
Punchbuggy
Mugrunty Posted at 2017-7-27 17:45
Been suggested and tried - no difference. But please feel free to try - who knows.
But what I WOULD like to try, is if someone who has had a successful update to v.106 could use dumbledore to backup their installation and post it on the forum. My personal suspicion (and some others) is not with the firmware itself, but with the integrity of the Assistant 2 download and subsequent upload to the craft. Direct flashing of a 'sound' installation will confirm that.
Anyone who has had a successful installation please consider helping solve this enigma for your compadres. Oh, and DJI... ;-)
2017-7-27
JockC
Punchbuggy Posted at 2017-7-27 18:30
I think that's a possibility. It will be interesting to see the results.
On another note, I see that DJI Go 4.1.5 has just been released only a day or two after 4.1.4. That seems odd. If I was a synical person, I might think that it was released in order to catch those who used the utility to downgrade their firmware and maybe force them to upgrade again. Probably not but, in any  case, I'll wait a few days after others have tried it before I update. I think we've seen too many dodgy firmware and app updates to simply assume that we should install them as soon as they're available.
2017-7-27
Flyin Ryan 420
Flight distance : 2334925 ft
JockC Posted at 2017-7-27 19:02
I lost my map upgrading to 4.1.4 on iPad Pro 9.7. Still haven't received 4.1.5 yet. I agree. Way better off waiting.
2017-7-27
fans0e00ebfc
So updating to 4.1.4 -4.1.5??? Yes or no...wow what a nightmare!
2017-7-27
beeper
Did anyone ever get the beta firmware that was promised?
2017-7-28
Pareja IV
Flight distance : 1084961 ft
beeper Posted at 2017-7-28 02:08
Not yet, still waiting
2017-7-28
Zisojohn
Greece
Flyin Ryan 420 Posted at 2017-7-27 19:19
re - install and you are gonna be ok!
2017-7-28
AlexDw
Flight distance : 609514 ft
Russia
I have a Phantom 4 firmware 503, g to go 4.1.5 all works well.
2017-7-28
gyrex
Flight distance : 7454275 ft
Maldives
What I'd like to know is why this troubleshooting has to be done by the customers and not by DJI. Still no official response from DJI and all their customers are left having to try and resolve these issues that DJI have thrust upon them. This is truly disgraceful. No help or acknowledgement from the manufacturer whatsoever. This is no way to treat your customers and no way to run a business.
2017-7-28
fans7f228480
Zisojohn Posted at 2017-7-28 03:52
I am still running 4.1.3 on my I Pad 3 mini not seen the 4.1.4 or 4.1.5 update yet, even asked for it to check and came back saying was on the latest firmware on DJI Go 4, Regards TJK.
2017-7-28
AlexDw
Russia
I have a Phantom 4 firmware 503, DJI  GO 4.1.5  everything works well.
2017-7-28
Slipstrm111
Flight distance : 5256 ft
gyrex Posted at 2017-7-28 04:43
Exactly! I have seen nothing from DJI to acknowledge there is an issue. Promised firmware by supposed DJI forum members only to be left in the cold. If that was my company I'd make some dam serious changes to my personnel lineup. I have been in the tech sector for 35+ years and I have never seen such bad service. Tech support is non existant. I fear that since some of the severe issues have been isolated and a way to roll back to previous versions of FW that DJI will be even more mute. (If that's even possible)
2017-7-28
Flyin Ryan 420
I did. Reinstalled twice. Still no map. Even with 4.1.5 still no map.
2017-7-28
Flyin Ryan 420
Well took a drive with iPad and boom map came back and all is well. Really appreciate you trying to help. Thank you
2017-7-28
Flyin Ryan 420
Actually if I unlock rotation in maps close app and reopen map is gone. If I lock rotation and close app and reopen it's fine. Strange. Can you try this?
2017-7-28
GrangerFX
Flight distance : 817713 ft
Dear DJI. Every day you don't communicate, don't fix the current firmware, don't allow us to load the previous firmware and don't resolve the long standing limitations such as the altitude restriction is another day that more users flock to the third party firmware loading solutions and hacks. You have lost control of your platform and you have only your management in China to blame. Whatever good will you hoped to achieve by placing restrictions on your products you have lost by encouraging hacking of your firmware. This was predictable from the beginning. You should have known it would happen.
2017-7-28
