Booradley
Flight distance : 12096457 ft
What's going on Tiago?
Have you been able to fix this yet?
You may have already heard this before but I thought I would share with you what worked for my Samsung Galaxy Tab S with 16gb. (At least so far for the first 2 full flights)
Just to recap so we are on the same page with our issue. My app would freeze, drop, or stutter after a few minutes of flight regardless of how far away it was. I'd usually notice it when it was further away, I truly believe that was just because it takes a few minutes to fly the thing far away. So I blame that as a coincidence because it continues to have the same issue when I bring it back closer and reload the app.
That being said, I can validate other claims on this thread for a work around until DJI releases a patch. With the exception that the solution I read involved version 1.1.9, I am using version 1.2.
Prior to doing any of this I did clear my video cache on the DJI Pilot app. I also, (AND THIS SEEMS TO BE THE COMMON DENOMINATOR WITH MY SUCCESS) went into Settings > Applications > Google Play > and clicked on "DISABLE." It basically uninstalled it or reverted back to a version I can't even use on my Tab S any longer. I'm only ok with that for now because I consider it temporary and I fully I expect an official fix to the issue.
This first step may not be necessary but I did it anyway:
1. Went into settings > applications and then went through every single application and "Force Stop" every single one.
2. Turned off the wifi in settings (which is recommended in the user manual)
3. I previously downloaded the 'Android Smart Task Manager." I used that to highlight every single task and killed every one of them.
Fired up the DJI Pilot Application and as the original poster described, it was, "smooth as butter."
That literally marked the first time I have been able to watch the live feed and felt confident with it. It was very reactive and even at max distance, very responsive.
I truly hope that helps you for the time being. After so much trouble it still feels like relief. But I am still disappointed that this has yet to be fixed.
Does anyone know if the follow feature works? How about setting way points with maps and GPS? |
