Phantom 3 1.2.6/1.2.8 Firmware Update Issues and Resolutions
At DJI we are dedicated to creating the world’s most advanced flying platforms and camera stabilization systems. This dedication extends to ourdesire to provide quality products that meet and exceed the needs of our customers.
Recently however, we have had reports of a number of issues arising from our latest firmware upgrade, specifically upgrading from 1.1.9 to 1.2.8 onthe Phantom 3 Advanced and from 1.1.9 to 1.2.6 on the Phantom 3 Professional. We sincerely apologize for any inconvenience caused and we are pleased to say that after extensive research and over 1000 flights, resolutions are now available. We would also like to extend a special thanks to users who reported the problems to us and assisted us as we worked on fixes.
If you have experienced any issues with your Phantom 3 Advanced or Phantom 3 Professional, please see below. If your issue is not below please let us know and we will work to resolve it as soon as we can.
1. Non-visual live feed image, i.e. a blank screen that appears instead of a camera feed.
Reason: Certain chip pins on the SD card are not connecting properly tothe circuit causing the camera to start up abnormally, making the screen turn black. Solution: Remove the SD card and re-install it tightly. Further solution: The camera startup process is being refined to take into account possible connectivity issues with the SD card. If necessary, DJI will repair affected units as quickly as possible.
2. Increased lag and screen flicker.
Reason: The DJI Pilot app is extremely complex, causing it to place highdemands on your mobile device’s processor and power consumption. This is especially true of three functions. a) Live feed, location map and Flight Route Recording all draw on processing power. b) When activated, the Video Editor automatically transcodes your live feed and creates your video in real time using your phone’s processor c) When the remote controller is connected to an iOS device, your iOS device will specifically use a Central Processing Unit (CPU) core to deal with data authentication computation. All of these functions increase the power consumption of your mobile device, in turn causing its temperature to increase. Most devices will lower processing speed when a temperature threshold is reached, slowing down the app causing lag and flicker.
Suggested solution: a) Activate hardware decoding on your mobile device in the DJI Pilot app to reduce demands on your mobile device’s CPU.
b) Choose a lower code rate under Image Transmission Quality assmaller files decode more efficiently.
c) Shut down any unused application programs, or activate “Flight Mode”
d) Keep your mobile device in a cool place whenever possible and keep it out of direct sunlight when flying outdoors.
Further solution: We will continue to optimize the DJI Pilot app, increasing computation efficiency and lowering power consumption to ensure that it always runs smoothly
3. Flickering screen and/or a blank screen during flying.
Reason: When the Phantom is flying at an extended distance, the angle of the antennas is essential to maintain a strong signal. Solution: Refer to the user manual and adjust the antenna angle.
We would also like to take this chance to share some good news with everyone. Many users have suggested that we provide more versions of the firmware so you can choose which one to use. This is something that we have taken on board, and we are delighted to announce that we will be making that happen as soon as dedicated engineers assess the best possible way to make this available.
In the future, there will be two versions of the firmware for you to choose from, the previous version and the new one. This means if for any reason you are not satisfied with the latest firmware you can revert back to the previous one.
We are constantly working to ensure that our customers are satisfied and will continue to optimize our products and provide the best service we can. If you have raised a problem about your Phantom 3 on the forum and it still has not been resolved, please contact our dedicated customer service team and provide as much detail as possible about your issue. They will be more than happy to help you.
Thank you for your sincere understanding.
DJI
