DJI Assistant2 software now available for Apple
1234Next >
300115 136 2016-3-18
Lb650
Flight distance : 1217762 ft
DJI-Ken Posted at 2017-3-6 09:43
I'm on Sierra 10.12.3, can you update?
From what' I read there is a problem wiith sierra and or the app.  I think I will wait till your team gets it fixed
2017-3-6
DJI-Ken
Flight distance : 1515312 ft
Lb650 Posted at 2017-3-6 12:54
The app has nothing to do with the Assistant2, calibrating the sensors works just fine for me on my Macbook Pro or my PC.
2017-3-6
Lb650
DJI-Ken Posted at 2017-3-6 13:25
Sorry. Not the go app.  I meant the assistant.    When I open the dmg file for assistant should I see 2 files , the driver and the program itself?     I only see the program itself  no driver     It's strange because the assistant works for everything but the sensor calibration
2017-3-6
DJI-Ken
Lb650 Posted at 2017-3-6 18:37
That's strange that the program is there but not the sensor calibration.
Try deleting then reinstalling.
When I install on my Macbook, I have to go to the security settings and let the program install then right when it says successfully installed another box pops up to the HoRNDIS installer. I do that then everything works fine.
2017-3-7
Lb650
DJI-Ken Posted at 2017-3-7 07:54
Yup that's exactly what mine does. The assistant installs successfully and then it prompts you to download that  "hoRNDIS" driver     I've removed and redownloaded it prolbly 5-6 times with the same out come   Everything works but the sensor calibration. Side note, I don't need to calibrate the sensors, I was just trying to familiarize myself with the program should the need arise. That's why I was curious if the assistant will let you calibrate even if no error comes up in the go app..   or I guess maybe I will have to upgrade to sierra
2017-3-7
DJI-Ken
Lb650 Posted at 2017-3-7 08:29
There's no reason to calibrate the sensors unless the app says it's needed or you experience issues. So I would just leave it as is.
But go ahead and upgrade to Sierra just to see if the option shows up.
2017-3-7
Lb650
DJI-Ken Posted at 2017-3-7 08:36
You bet.  Thanks for the help
2017-3-7
DJI-Ken
Lb650 Posted at 2017-3-7 08:53
No problem, have a great week.
2017-3-7
fansdde70571
Assistant 2 doesn't recognise A3 but picks up light bridge any ideas anyone ??
2017-3-16
DJI-Ken
fansdde70571 Posted at 2017-3-16 14:48
Do you have the latest version of Assistant2 and are you on the latest firmware. ?
If you are on firmware 1.3 or lower, use the Assistant2 1.0.5
http://www.dji.com/a3/info#downloads
https://dl.djicdn.com/downloads/a3/20170118/A3+Release+Notes.pdf
2017-3-17
user8652f45beb
Flight distance : 35289 ft
Assistant 2 not able to open in MacOS Sierra 10.12.4.
Option under System Preferences / security to Install All no longer avaialable.
Need a solution now!
2017-4-17
DJI-Ken
user8652f45beb Posted at 2017-4-17 22:51
Do you have it working now?
2017-4-18
fans40d0befd
Dominican Republic
Assistant 2????
Macbook Pro Sierra 10.12.4.  Installed Assistant 2 with no errors.  Restarted the Mac no icon shows up for Assistant 2.  Deleted the DMG File, downloaded it again, and installed it again, again with no errors.  DJI, Assistant 2, nothing appears in Programs or Desktop.  Anything else i can try???
2017-5-3
DJI-Ken
fans40d0befd Posted at 2017-5-3 19:51
You don't see the HoRNDIS installer box that I showed in post #83?
After installing the Assistant2, look for this box.
2017-5-4
NE.UK
Flight distance : 25371 ft
Exib Posted at 2016-3-18 11:14
Will not let me open it
Assistant” can’t be opened because it is from an unidentified developer.
right hand click and then select open
2017-5-9
SlickWilly71
I have a mavic which I downloaded the firmware update. I calibrated compass and now have error messages that front sensors need calibration. I obviously have no untextured surface to calibrate through the app in my entire surroundings. I spent the afternoon with online support. I have the most recent OS (el capitan I believe) I downloaded the dji assistant 2 successfully as well as HoRNDIS driver. Restarted the iMac and can't find app anywhere. Did this several times with same result. Very frustrating afternoon. What could I be doing wrong? I've only flown the mavic 2 times in beginner mode and would love to get it back up and running. Please help.
2017-5-10
SlickWilly71
Correction. I am running OS Sierra
2017-5-10
SlickWilly71
I also plugged the mavic in to the computer hoping to launch the app to no avail
2017-5-10
DJI-Ken
SlickWilly71 Posted at 2017-5-10 15:35
The app is only on mobile devices, not the computer. The Assistant2 is run from the computer.
You said you installed it correctly and also the HoRNDIS.
Can you use the Finder to search for the Assistant2.
2017-5-10
SlickWilly71
I tried. not there. Have no idea where it's downloading to
2017-5-11
DJI-Ken
SlickWilly71 Posted at 2017-5-11 00:28
And you are downloading from the DJI website from the downloads page for your aircraft?
2017-5-11
SlickWilly71
Ok. I've finally successfully downloaded assistant on to iMac. Went through tutorial for calibration. Entered calibration full screen and nothing. . Just a blank white screen. Wth am I supposed to do to calibrate?!
2017-5-11
DJI-Ken
SlickWilly71 Posted at 2017-5-11 10:18
Can you post some screenshots.
2017-5-11
SlickWilly71
Yep. Just a sec. reinstall now. Tried daughters windows laptop but did not recognize mavic via USB
2017-5-11
SlickWilly71
I've done everything. Downgraded firmware. Reinstall to factory settings. Reinstalled assistant numerous times. Still nothing
2017-5-11
SlickWilly71
ok. On tutorial 3/3 I'm see red writing stating "frame alignment error" then when click calibrate now. Goes to white screen (no red box) can't figure pic upload from iPad now
2017-5-11
DJI-Ken
SlickWilly71 Posted at 2017-5-11 13:16
You cannot line up the green corners with the box?
2017-5-11
SlickWilly71
During tutorial?
2017-5-11
DJI-Ken
After tutorial.
I get a blank white screen but only for a second, then the calibration box pops up. Can you delete and reinstall it.
2017-5-11
SlickWilly71
I've deleted and reinstalled 4 times. Don't get any of that. Only blank white screen
2017-5-11
SlickWilly71
Ok. Tried again on windows laptop. Didn't recognize again. But found an old version. 1.07? I believe and installed. I thought success! Because it recognizes my mavic ( driver issues for your software people to work on) but alas. I get to calibrate and enter full screen.... only white screen again!!!!! Is it my drone? What could be happening?
2017-5-11
SlickWilly71
Was finally able to calibrate through the app using a white bedsheet. Still only white screen on both computers though for full screen calibration. Would like to do a proper calibration.
2017-5-11
SlickWilly71
SlickWilly71 Posted at 2017-5-11 16:56
Ok. Crashed drone today. (Related to improper sensor calibration?) camera not working. Cables look intact. Wifi hooks up when in assistant. Camera must be bad so I'm sure I have to send in on my dime. My question being, how do I ensure they check out sensors and internal firmware to see if internal problem vs assistant 2 software glitch. Since I downloaded assistant on 2 computers multiple times I feel maybe the issue is internal? Please help Ken
2017-5-16
ROGUE 1
How do I activate my pro res and DNG on my
Inspire 2? I've tried the dji assistant and can't seem to figure it out
2017-5-17
DJI-Ken
ROGUE 1 Posted at 2017-5-17 18:18
It's not an option on screen fro you?
http://www.dji.com/service/inspire-2-license-key/guide
2017-5-18
steve13
Flight distance : 274409 ft
I have a serious problem with my Mavic pro. The problem is the following. When I start flying as soon as I pressed a camera button take a shot whole the screen goes black, I have did land the drone restart my phone Andrea start the controller as well as drone. Why? Why? Why. I have paid a lot of money for this crazy drone
2017-5-28
fans407ddf21
Argentina
Buenas tardes. Tengo un problema con mi drone. Me aparece visión system error. Quisiera saber si me pueden ayudar
2017-6-2
fans4fe7e9b9
Flight distance : 2415 ft
I have installed the Assistant software on my Mac, and the application runs, but it doesn't do anything. All I have is the opening screen, showing a diagram plugging a USB cable into the computer. Is there any documentation? Can I connect my P4P controller and download images from the memory in the controller? I plug it in, but nothing changes, and there are no buttons or menus to click.
2017-6-5
fans3f50604d
I downloaded assistant 2 for mac. Running Sierra. Download .dmg, open, install, install the horn thingy, restart, search for assistant2 it is nowhere. Twice I've done this. Says successful - but the assistant is nowhere to be found
2017-6-8
H82Bpor
Flight distance : 27733 ft
DJI-Ken Posted at 2016-10-20 14:53
Thank you very much, I really appreciate the kind words..
But I'm just doing my job, as well as all the other forum moderators.
What would be great is a way to register your craft using the assistant, I have been unable to, for about 3 days now and getting really frustrated.
2017-6-12
1234Next >
