@ Rich
Did some additional testing today to find out how the iPad Mini 4 holds up when putting additional load on it.
A/C Firmware 18.1.00, Inspire 1 Pro with X5 Camera GoApp 2.8.7 R/C Firmware 1.6 iPad Mini 4 64 GB Cellular but using Hotspot via WIFI from iPhone during test. So wifi was active during entire test. Temperature; 25C but high humidity. Used Shou screen recorder to record entire time.
Test A:
- Shou recorder set at 480P
- Video Cache on (recording)
- Took photos/recorded video
Test B:
- Video Cache off
Test C:
- Shou recorder set at 720P
- Video Cache on
- Took photos/ recorded video
Test D:
- Video Cache off
- Took photos/ recorded video.
Test result: Did not see any problems with the iPad even using wifi, Recording Screen with Shou @720P, Video Cache on as well as doing video with the X5, all at the same time.
Might be more of a firmware issue then iPad Mini overload, have to add that temperature was not as high as our fellow flyers down south have to deal with, the added heat will surely add to any issue.
EDIT: Another factor that should be considered, non of my testing sessions exeeded 10 minutes since I am running the X5 (battery capacity) |
