1-week-old mavic 2 pro lost control during landing and crush
12Next >
7193 46 2018-9-15
Williamyao
Flight distance : 44131 ft
Hi there,
Yesterday I took a video clip for my uni. After done, I was trying to land my Mavic 2, but the drone was just lost control and fell into ground. It wasn't high, about 10 meter, and everything ran well before falling, but suddenly it looked like one or some of motors just lost power. The circumstance was all good there, it was not windy, signal and GPS was strong, battery was fully charged. The drone was always under my sight during the flight. but it just fell above my head and crushed.
The damage shows on picture.
Gimbal and one of motor are totally broken, another motor gets seperated. Some parts of the drone are misplaced, there is a number of scrath all around the aircraft as well.
Here is the last moment when it lost control and fell.
I am going to report my case, but is my drone still repairable like that? Otherwise I would just choose replacement process instead.
2018-9-15
thehippoz
Flight distance : 23 ft
It looks like you hit the tree here
2018-9-15
HedgeTrimmer
From damage, it looks cheaper to replace than to repair.
2018-9-15
Williamyao
thehippoz Posted at 2018-9-15 20:37
[view_image]
Not really, it is totally open area. I was trying to land on the left side of the footpath, where is the grass field showed on your picture. The closest tress is about 20 meter away at least. I have synchronized the flight record. The drone was even hovering at that position for seconds before my last pulling down operation if you could check the profile.
2018-9-15
Williamyao
HedgeTrimmer Posted at 2018-9-15 21:09
Yeah, you are right. I just checked price list of Mavic pro components(I didn't find the list of Mavic 2), the repair cost is added up to 200 USD at least, which means it should be more expensive for a Mavic 2. The drone is under DJI care, but I am doubting whether I should afford the extra fee, because the drone was not operated wrong manually.
2018-9-15
nixuspix
Flight distance : 2864974 ft
Latvia
O no! I am so sorry for your accident. Hope you'll recover soon. Can You please provide us with a flight record data by pasting your last flight data from folder in mobile device DJI/DJIGO4/FlightRecord
here:
http://www.phantomhelp.com/LogViewer/Upload/
2018-9-15
Williamyao
nixuspix Posted at 2018-9-15 22:18
here:
I have uploaded the file, here is the link.
http://www.phantomhelp.com/LogViewer/1JL9YCTVWUEZW1DMIR2D/
2018-9-15
Wachtberger
Flight distance : 261509 ft
Williamyao Posted at 2018-9-15 23:21
I am very sorry for your crash! To me the flightrecord does not explain it, but others might see more. In any case you should open a support ticket with DJI and let them analyse all data. There recently was another case with a motor malfunction: https://www.dji.com/support
2018-9-15
Suren
Flight distance : 13498560 ft
South Africa
That much damage from a 10 meter fall, looks bad
2018-9-15
Suren
South Africa
Log just ends and does not show landing, you also seem to have had a warning about high winds
2018-9-15
nixuspix
Latvia
So the red point on the map is the point, when a single error was reported:
"Gimbal Roll Reached Movement Limit"
And then in 1.6 sec the altitude dropped from 39 ft to zero,
It's not clear why such error could cause the fall down of the drone.
As it was told above, open the case with DJI for further analyse and repair.
2018-9-15
User1
Flight distance : 4974 ft
Hungary
Landing is sport mode? Without sensors thats seems like a fast fall not landing.I see in your log you start landing from 30 meters. You pull down stick but you forgot in sport mode the breake length is longer and hit the ground.
I dont understand why ppl use Sport mode in this area.
2018-9-15
Koelkop
Flight distance : 22814806 ft
South Africa
User1 Posted at 2018-9-15 23:57
Have you ever landed in sport mode??
Then you will know it does not switch of bottom sensors...
2018-9-16
Sky Donkey
Flight distance : 355157 ft
why was you trying to land 185.8ft from the original take off point 2mins 30 seconds after take off?  something doesnt add up
from 2.28.1 to 2.29.5 you had left stick full down in sport mode
At 2.30 .4 you push full up left stick at a height of 12 ft.
At 2.30.7 game over …
Looks like the momentum of sport mode in a full speed decent caused the crash … Im no expert
Topic title is rather Sensationalist .   not quite the way of things ....
2018-9-16
msinger
Flight distance : 228255 ft
I don't know that it was too windy to fly, but it was definitely windy.
2018-9-16
Williamyao
Suren Posted at 2018-9-15 23:54
Honestly, the wind wasn't strong, and it was just one breeze that triggered the alarm. You can see it wasn't continuing. There was no information about landing because the drone fell into parts, and the battery jumped out of its slot and broken.
2018-9-16
gnirtS
Flight distance : 5712575 ft
That wind speed is above the maximum level DJI say they drone is resistant to so yes, in p-gps mode it'll make little or no headway at all into it.  And it was at that level for a fair chunk of the flight.
2018-9-16
hallmark007
Flight distance : 11959747 ft
Williamyao Posted at 2018-9-16 02:37
There is very little in your logs that show any problem, at the end of your log it shows you in sport mode 100% down on throttle craft at 9 metres , Aircraft log then shows very quickly -1 ft,
Was the ground you were flying over on a slight incline from where you took off from ? It looks that way on google maps, but hard to tell, you must also remember no sensors operating in sport mode.
Dji will be able to retrieve a lot more info from .dat file from your aircraft which should tell some more.
Let us know how you get on and Good Luck.
2018-9-16
Williamyao
It doesn't matter which mode I was using to land, the drone is designed to fly under all three modes including landing. The height was not low enough to trigger the sensor when the drone lost control, and as you can see, I didn't pull it down straightly, I landed it by stages.
2018-9-16
A CW
Flight distance : 14754314 ft
Ouch! Sorry to read that - hope you get back in the air soon.
2018-9-16
DJI Gamora
Hi, thanks for reaching DJI Forum. We do feel sad about what happened. Have you already contacted this to process replacement case? We're here to help you. Thank you.
2018-9-16
hallmark007
You see your launch area marked red, crash area over to the righ you can see the ground rising.
2018-9-16
Sky Donkey
Williamyao Posted at 2018-9-16 03:00
as per my previous answer .... At what time and attitude on your flight logs ?did the drone lose control and fall from the sky? It looks like it was responding to stick commands in sport mode?
2018-9-16
R&L Aerial photography
Flight distance : 298100 ft
nixuspix Posted at 2018-9-15 23:55
Gimbal roll reached movement limit error can be caused by wind or erratic flight,it can be duplicated by turning  the drone upside down while powered on...
2018-9-16
Sky Donkey
No one takes off for a flight with the intentions of landing 185 ft away 2 and a half minutes later..
at 2.5.2 you had a high wind warning. You were flying at 182 ft in tripod mode.
Either by accident or intentionally your switched to sport mode.. looking at your flight path it appears as though you had problems controlling the craft after this time, probably attributed by the high winds...
If you look at 2.29.1 the drone is on its side...probably blown by wind .while you pull the left stick fully down, taking power out of the craft to correct its own powered decent.  ,,
2018-9-16
gnirtS
Possibly he was in tripod mode, wondered why it wasn't "responsive" (i see no reason why anyone would use tripod mode deliberately at that altitude) then flicked the switch, missed the central P-GPS setting, ended up in sport and lost it from there.
Its in a very strong wind - at or more than the mavic is rated for.
2018-9-16
Sky Donkey
gnirtS Posted at 2018-9-16 03:45
Your probably right or its a combination of factors highlighted by a few member in this topic. ... im the first in line to bash DJI. Poor support, announcements, updates. Ect. But in this case its probably wrong to use the sensationalist topic title …
hold your hands up op and say you goofed... there's no shame  I forgotten the number of craft ive smashed up myself.
2018-9-16
Folkestone
Flight distance : 843199 ft
What is the new Mavic's wind rating?
2018-9-16
msinger
Folkestone Posted at 2018-9-16 04:20
29-38 kph (18-23 MPH)
2018-9-16
Gimpy
The "Gimbal Roll Reached Movement Limit" was a symptom and not the cause of the problem. The problem can be seen to have started just before that at 2:28.8 when pitch when to -26.3 and roll to 15.1, after which it begins to fall. Assuming he wasn't flying in a hurricane, there are no control stick inputs that should produce that attitude.
2018-9-16
Williamyao
Sky Donkey Posted at 2018-9-16 02:17
I was following the drone and just steps away from the crush point. I was the white point on the screenshot which I posted earlier.
There is a radar-look staff above the mimic joystick in the  log viewer page which is the bubble level showing the attitude of the drone.  At 2m 28.9s, the drone lost its balance completely and rotated until crushed.
I don't think the performance like that was under my control.
2018-9-16
Williamyao
Sky Donkey Posted at 2018-9-16 03:37
I was filming a slow motion shot which followed the footpath and climbed up in tripod mode. When it was done, I surely switched into sport mode to get my drone back quickly and to move to the next spot.
2018-9-16
Williamyao
DJI Gamora Posted at 2018-9-16 03:02
Thanks for replying. I couldn't open a replacement ticket because it is only available on working days. Since that, I just report a repair case.
The case ID is CAS-2238418-Z4G8B3
2018-9-16
DJI Gamora
Williamyao Posted at 2018-9-16 05:02
Thanks for the fast response and giving me your case number. I will contact the correct department for us to help you with this. Have a good day.
2018-9-16
Williamyao
A CW Posted at 2018-9-16 03:01
Thanks for that. Best wishes to you.
2018-9-16
Williamyao
DJI Gamora Posted at 2018-9-16 05:06
Thanks, you too.
2018-9-16
Folkestone
msinger Posted at 2018-9-16 04:28
Thank you!
Guess I won't be flying for a while longer.
2018-9-16
DJI Diana
Flight distance : 2408 ft
Hi Williamyao. I am sorry to know what happened to your drone. Thank you for providing your case number. We will be sending you notifications on updates with regards to your case as soon as possible. Thank you for your patience.
2018-9-16
A CW
Williamyao Posted at 2018-9-16 05:15
Thanks mate
2018-9-16
Williamyao
DJI Diana Posted at 2018-9-16 08:18
Thank you.
2018-9-16
12Next >
