JerryDavis
While I still have questions about the way the DJI RTK base station works, this is what I'm looking at as a possible best practice (in California since we're using CRTN with our GNSS system) for field and lab methods, at least for my work in a very large study montane meadow (10 sq km), incomplete (~90%) cell coverage, and following from about 4 years of mapping to look at change:
1. For each flight plan, put out at least 3 GCP targets, coordinates captured in Field Maps with the Eos Arrow Gold & CRTN, so in California SRS Epoch 2017.50 (NAD83).
2. Set up the base station near the middle of the flight plan (each flight plan being ~1 sq km), with no adjustment of the coordinates.
3. Confirming that RTK is connected, run the flight.
4. Download the GCPs from AGOL as a CSV.
5. Reproject those esrignss* GCP coordinates to WGS84 UTM, and reconfigure for Pix4D input as a CSV file with id, X, Y, Z (HAE), horiz precision, vertical precision. [I'll do this in ArcGIS Pro and then Excel].
6. Process in Pix4D as WGS84 UTM.
For a new project, we might use some variation on NAD83 (2011, or maybe a newer epoch), but the amount of effort in reprocessing our earlier data, captured as WGS 84 UTM using Trimble GeoXH, is prohibitive. Also, our project involves multiple GNSS devices, all but the one Arrow Gold using SBAS correction giving us about 30-40 cm accuracy, and most of those output to WGS 84. Given the >1 m difference between the WGS84 and the California SRS Epoch 2017.50 (NAD83), it seems we should go with what most of our devices use, to avoid confusion.
My rationale for just using the base station coordinates is that it's easy to screw up the base station adjustment process out in the hot sun, and there will likely be an offset to deal with anyway. After testing on a local site, I'm reasonably convinced about the internal consistency the RTK solution is providing, with the direction and magnitude of offset pretty consistent. Could probably get away with just one GCP, to see the offset, but we need check points anyway. Definitely can't go with no GCPs, since in my tests the base station coordinates can vary each time you set it up on the same point, so we're dependent on the internal consistency followed by offset.
I'm still not certain about how the DJI D-RTK2 Mobile Station works, however, since the base station will stabilize at significantly different absolute coordinates (often > 1 m different, in X, Y, or Z) while at the same location when powered on anew each time, as I document in https://forum.dji.com/forum.php? ... 111&pid=3061777 . Since the way RTK works is that the rover's position is only very precise relative to the base station coordinates, with absolute coordinates having the same error as the base station's error, I guess this makes sense, but I'm just surprised at how much the base station's absolute coordinates vary each time you power it up at the same location. But this points to the true necessity of getting good coordinates of at least one GCP using a highly accurate GNSS unit; I'm using three GCPs for now.
