SeehawerB
Flight distance : 5414203 ft
Couldn't believe that this is true, until first flights of the year today.
- Avata flighs erratic in N and S, shudders repeatingly at some random time and the gimbal looses the horizon, hangs to one side
- when reaching the configured max height it shudders, goes to N and the gimbal hangs to one side, needs some careful flying that it "looks straight" again, very weird, never had this before
AND THIS IS THE WORST:
In the middle of normal flight (mode M(, the Avata shook all of a sudden, the gimbal went into a strange crooked position and it accelerated at full throttle over and over without being able to use the remote control at all. You are a passenger and watch.
I saw a large expanse of water passing below me (on a field, about 500m away), then I saw cattle (about 700m away) and I could only pray that the Avata didn't go down in the water or between the cattle. Then I saw the blue sky with clouds in a more relaxed way, the Avata seemed to have reduced the speed. I fumbled at the camera angle, explicitly switched to N mode and tried to get a feeling WHERE the drone is and how I could get it back to me. It turned out that it hovered around in a good height and I took her home slowly, limbing.
Video and flight data will follow within the next days.
Conclusion for me: THE AVATA IS DANGEROUS with the current firmware. DO NOT FLY IT! It's a completey different drone than last year. Very bad and VERY PRONE DO GO HAVOC!
Note: I also flew my new iFlight Evoque today in AIR and it was a charme. Thought I could give the Avata a blast in a more easy manner at the end of the day. BUT BOY, WAS I WRONG!!!
I will not fly the Avata again with this firmware. DJI, you have a lot to fix here for sure. |
