Phantom 3 Series Newest firmware
1234
12938 156 2016-3-16
Lynx.1
DJI-Ken Posted at 2016-3-17 23:24
Can you post a video of the bad video feed?
Sorry Ken I think your missing the point ....
If the Vid feed is bad the only any to show you is to have some one film on the Phone/tablet he is using ...
video is saved to the SD card on the drone so if there is bad feed to the RC you will not see it ...
Take the Google play app ... 2 different tablets one runs 4.4.2 and the outher runs 6.0
Both have Wi-Fi link to RC but no Live feed and no telemetry ...
loaded it on to a Ipad and woow the sucker works with no glitches ... ya think It might be in the App...
Just have a look at the Rev's from the Play store .... Not good..
2016-4-4
DJI-Ken
DJI Team
Flight distance : 1515312 ft
pauldharmaratne Posted at 2016-4-4 07:35
Thanks DJI Ken any thoughts about using the HDMI module and setting the HD to dual feed. This is wha ...
You are defeating the purpose of using the app for video if you install a HDMI module ($100) then a HDMI monitor ($150min) just so you get clear no interference video. Plus you will need another mount attached somehow so the monitor will attach because you still need the tablet attached with the USB cable if you want to use any features. But if that's how you want to do it then yes it will work.
First try to borrow a friends device and also film a lower resolution and make sure it plays back good on your computer.
2016-4-4
DJI-Ken
DJI Team
Lynx.1 Posted at 2016-4-5 00:05
If the Vid feed is bad the only any to show you is t ...
No it is not in the app that is causing the issue. Just a device with higher performance specs is required.
2016-4-4
FAS1
DJI-Ken Posted at 2016-4-4 12:45
No it is not in the app that is causing the issue. Just a device with higher performance specs is  ...
And of course, this all comes without an updated device list. You guys are still promoting old, outdated devices that cannot correctly run the GO app. The issues may not be the GO app, but the GO app caused the requirements to be raised. And as such, you recommended device list also needs to be updated.
If I wanted to use the GO app, I just wasted $163 by buying your "recommended" device that was outdated literally 3 weeks after purchase. After farting around with trying to make it all work, you know, because the problem(s) have nothing to do with DJI GO app, I missed my return date by 2 days. And now you are saying I need a newer, more powerful solution. Weak, very weak, DJI.
And the hilarious part? The fact that my phone, which isn't on your 'list', performs flawlessly.
2016-4-4
DJI-Ken
DJI Team
FAS1 Posted at 2016-4-5 00:58
And of course, this all comes without an updated device list. You guys are still promoting old, ou ...
I don't know what you mean, all the recommended devices are listed and they have been the same ones for a while.
iOS Version v2.7.1. Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus,iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular.This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v2.7.1. Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1, Huawei Mate 8
2016-4-4
FAS1
You don't know what I mean? You stated yourself that the app isn't the issue, it is the power of the monitor/device. Well, my Tab 10 was powerful enough until the app was updated and required even more processing power. That is directly on you guys. We, the ones who followed your (not yours personally) advice, simply do not have the resources to constantly be buying newer and newer devices because you guys get a wild hair and decide to change things, then claim zero responsibility.
My question is this...The app version 2.6.0 worked flawlessly on my Tab 10. DJI changed the app and now I have nothing but problems running 2.7.1. This isn't a tablet issue, but may be a processor issue. An issue that only began, thanks to higher requirements from the new app. So then, how is this not the apps fault?
Funny how after the update was released that all these threads of problems began. No video, laggy video, poor connections, etc...
2016-4-4
FAS1
And Litchi works flawlessly. GO does not. Same Tab 10. So please explain how/why I need more processing power? And I have 4.4.2 Android, BTW.
2016-4-4
FAS1
DJI-Ken Posted at 2016-4-4 13:03
I don't know what you mean, all the recommended devices are listed and they have been the same one ...
2016-4-4
DJI-Ken
DJI Team
FAS1 Posted at 2016-4-5 07:04
https://www.youtube.com/watch?v=w-etSknn0OI
https://www.youtube.com/watch?v=8LjBk-YpNOw
Why, because it's not one of the recommended DJI devices.
I'm sorry but you will have to upgrade if you want to use the GO app.
Also, if you do upgrade, make sure not to run both apps at the same time.
2016-4-4
FAS1
DJI-Ken Posted at 2016-4-4 20:07
I'm sorry but you will have to upgrade i ...
        Device        Type        Screen Size        Processor        RAM        GPS
        Acer Iconia Tab 8        Tablet        8 inches        1.33 GHz        2 GB        Yes
        Acer Iconia Tab 10        Tablet        10.1 inches        1.3 GHz        1 GB        Yes
If I need to shell out more money for another tablet, 4 weeks after buying the tablet your company says works, guess who will be sued? You can't just try and wash your hands and say "I'm sorry but you will have to upgrade". You are the face of DJI on these forums.
And not both are open at the same time. I thought you guys were professionals. I am the only one to experience problems with DJI, using the equipment DJI says emphatically will work?! But now you state I must upgrade because it isn't on the list?! Puff, puff pass, brother!
And if I sound upset, it is because I am. I have spent the past 11 hours working on this issue. You totally not giving a crap and saying I need to upgrade instead of attempting to help is very disconcerting to me. Especially since I followed all the DJI rules. Hell, it takes me longer to set this quad up than I get to fly it! And all you have to say is BS that my device isn't on the list. Well, look at what is in BOLD above. THAT is the device I specifically purchased based on DJI recommendation of what works.
2016-4-4
DJI-Ken
DJI Team
FAS1 Posted at 2016-4-5 09:29
This is what you said "If I wanted to use the GO app, I just wasted $163 by buying your "recommended" device that was outdated literally 3 weeks after purchase."
And you have an Acer Icona Tab.
I'm not following where you say you bought that based on the DJI recommended devices but that's NOT one of the recommended devices.
If you have one of the recommended devices and cannot get the app to work, then let me know and I will talk to app department.And I am trying to help, BUT if you are not using ONE OF THE DJI RECOMMENDED DEVICS there's nothing I can do except suggest you use a DJI recommended device.
2016-4-4
FAS1
DJI-Ken Posted at 2016-4-4 21:40
This is what you said "If I wanted to use the GO app, I just wasted $163 by buying your "recommend ...
DJI Ken, what is wrong with you? That stuff you are smoking is too harsh for you. You should wait for after work to toke up.
Now, don't tell me again that my device is not on the "recommended list" FFS:
http://www.phantomhelp.com/Tips/18/best-tabletsphones-for-dji-go
Android Devices
         Google Nexus 5        Phone        5 inches        2.3 GHz        2 GB        Yes
►►        Google Nexus 7 [2013]        Tablet        7 inches        1.5 GHz        2 GB        Yes
►        Google Nexus 9        Tablet        8.9 inches        2.3 GHz        2 GB        Yes
         HTC One        Phone        4.7 inches        1.7 GHz        2 GB        Yes
►        Huawei Ascend Mate 7         Phone        6.8 inches        1.3 GHz        2 GB        Yes
►        Huawei P8 Max        Phone        6.8 inches        2.2 GHz        3 GB        Yes
         Lenovo A3500        Tablet        7 inches        1.3 GHz        1 GB        Yes
         Lenovo Tab S8-50        Tablet        8 inches        1.86 GHz        2 GB        Yes
►        Nubia Z7 Mini        Phone        5 inches        2.0 GHz        2 GB        Yes
►        Nvidia Shield K1        Tablet        8 inches        2.2 GHz        2 GB        Yes
         RCA Voyager II        Tablet        7.1 inches        1.4 GHz        1 GB        No
►        Samsung Galaxy Note 3        Phone        5.7 inches        2.3 GHz        3 GB        Yes
►        Samsung Galaxy Note 4        Phone        5.7 inches        2.7 GHz        3 GB        Yes
         Samsung Galaxy Note 5        Phone        5.7 inches        2.1 GHz        4 GB        Yes
         Samsung Galaxy Note 8        Tablet        8 inches        1.6 GHz        2 GB        Yes
         Samsung Galaxy S4        Phone        5 inches        1.9 GHz        2 GB        Yes
►        Samsung Galaxy S5        Phone        5.1 inches        2.5 GHz        2 GB        Yes
►        Samsung Galaxy S6        Phone        5.1 inches        2.1 GHz        3 GB        Yes
         Samsung Galaxy S6 Edge        Phone        5.1 inches        2.1 GHz        3 GB        Yes
         Samsung Galaxy Tab 2         Tablet        7 inches        1.0 GHz        1 GB        Yes
         Samsung Galaxy Tab 2        Tablet        10.1 inches        1.0 GHz        1 GB        Yes
         Samsung Galaxy Tab 3 Lite        Tablet        7 inches        1.2 GHz        1 GB        Yes
         Samsung Galaxy Tab 4        Tablet        7 inches        1.2 GHz        1.5 GB        Yes
►        Samsung Galaxy Tab 705c         Tablet        8.4 inches        1.9 GHz        3 GB        Yes
         Samsung Galaxy Tab A         Tablet        8 inches        1.2 GHz        1.5 GB        Yes
         Samsung Galaxy Tab A        Tablet        9.7 inches        1.2 GHz        1.5 GB        Yes
         Samsung Galaxy Tab Pro         Tablet        8.4 inches        2.3 GHz        2 GB        Yes
         Samsung Galaxy Tab Pro        Tablet        10.1 inches        1.9 GHz        2 GB        Yes
         Samsung Galaxy Tab Pro        Tablet        12.2 inches        1.9 GHz        3 GB        Yes
         Samsung Galaxy Tab S2        Tablet        8 inches        1.3 GHz        3 GB        Yes
►        Smartisan T1        Phone        4.95 inches        2.5 GHz        2 GB        Yes
         Sony Xperia Z2        Phone        5.2 inches        2.3 GHz        3 GB        Yes
►        Sony Xperia Z3        Phone        5.2 inches        2.5 GHz        3 GB        Yes
►        Xiaomi Mi 3        Phone        5 inches        2.3 GHz        2 GB        Yes
►        Xiaomi Mi Pad        Tablet        7.9 inches        2.2 GHz        2 GB        No
Note: Tablets wider than 6.75 inches (including the case) will require an extender to be installed on the remote controller mount. This extender is designed well and will securely hold your tablet in place.
Note: The DJI GO app currently only requires GPS on an Android device when using the Follow Me feature or to reset the home point to your current location if you've moved elsewhere after taking off.
Note: Your Android device will work better out of the box if you follow these tips.
Now, please LOOK at the list! The second device listed. Can't miss it. What does it say? GET OUT! It says "ACER ICONIA TAB 10"!!! Guess what I bought... :@
But now I have you stating that it is not a recommended device. Yet this is the list everyone is referred to, when they ask what device to use...SMH
2016-4-4
sandmarkcontrac
I purchased a Phantom 3 advanced in feb 2016
I tried to use my Samsung Tab3 and my higher powered Asus tablet ( both worked intermittently) video feed would freeze on both.
So after looking at the list of devices from DJI I reluctantly purchased a Ipad Air2 just for the phantom using DJI GO APP.
One in 3 times it would give me a camera feed, the other times was a blank screen ( but I could live with that)
So I was happily flying the other day with a solid video screen and but kept getting prompted to update my RC, Aircraft and App.
So I upgraded following all the correct procedures, ( formatting SD card etc).
After It being a pain in the arse to do. ( multiple attempts) in now says on the App under (about)
Aircraft Firmware 1.7.60
RC 1.5.8
App ios 2.7.1
Ipad updated to 9.3.1
And now I have no video feed whatsoever and the log says everything is OK.
Really pissed off and I will be stuffed if I'm buying a new device (tablet)  just because these latest firmware updates are Bullshit!!!
Rant over.
2016-4-4
FAS1
http://smile.amazon.com/Acer-Ico ... _detailpage_o06_s00
2016-4-4
DJI-Ken
DJI Team
FAS1 Posted at 2016-4-5 09:51
DJI Ken, what is wrong with you? That stuff you are smoking is too harsh for you. You should wait f ...
This is the DJI recommended list of devices.
Whatever has been created from another website I cannot comment on.AGAIN, below are the RECOMMENDED DEVICES FROM DJI ! And you device IS NOT recommended by Phantom Help or DJI, only recommended by some users.
So I'm sorry but it looks like you bought a device that was only recommended by some users and not even the people who made that list.
iOS Version v2.7.1. Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v2.7.1. Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8,Huawei P8 Max, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
And watch how to talk to the moderators !
2016-4-4
DJI-Ken
DJI Team
sandmarkcontrac Posted at 2016-4-5 09:51
I tried to use my Samsung Tab3 and my higher powered As ...
I have an iPad Air (less performance than a Air2) and it works 100% fine.
Can you delete and reinstall the app to see if that helps.
And can you please do a screen record or what you are talking about no video feed at all. You can use Air Shou to screen record,
Also, can you post the hidden log file.
Here's how to view the hidden logs
2016-4-4
sandmarkcontrac
Hi DJI-Ken,
I had the device not detected on line 1500, and I then tried to drop back to the previous version on the Aircraft, and then reinstalled the latest version.
The no video feed im talking about relates to the fact that I cant see the camera on the Ipad, I can still control the phantom and any photos are on the SD card but I cant see what the camera is looking at on the Go app.
Ive tried deleting it and reinstalling the App ( lost my log details ( stupid me- didn't back up) restarted Ipad etc with still no luck,
Heres the Log .
[00264188]========== remo-con disconnect. boot(2) ============
[00264335]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00264371]Packet upgrade start...
[00264412]Packet checking...
[00264456]Packet vlink 01.06.0040 <-> 01.05.0030.
[00264520]Done.
[00264557]Version checking[1]...
[00264625][03 05][00] v34.2.0.9 -> v34.2.0.9
[00264690][03 06][00] v2.4.0.4 -> v2.4.10.7 need upgrade.
[00264745][04 00][00] v1.41.0.0 -> v1.41.0.0
[00264866][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00264944][12 00][00] v1.10.0.0 -> v1.10.0.0
[00265019][12 01][00] v1.10.0.0 -> v1.10.0.0
[00265096][12 02][00] v1.10.0.0 -> v1.10.0.0
[00265176][12 03][00] v1.10.0.0 -> v1.10.0.0
[00265211][15 00][00] v1.1.2.0 -> v1.1.2.0
[00265300][17 00][00] v1.1.1.7 -> v1.1.1.7
[00265420][17 01][00] v1.0.2.7 -> v1.0.2.7
[00265476][19 00][00] v1.0.8.96 -> v1.0.8.96
[00265510][01 00][00] v1.22.4095 -> v1.22.4095
[00265544][01 01][00] v1.22.4095 -> v1.22.4095
[00265596][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00265629]Done.
[00012031]========== remo-con disconnect. boot(15) ============
[00012064]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012100]Packet upgrade start...
[00012142]Packet checking...
[00012184]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012252]Done.
[00012284]Version checking[1]...
[00012373][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012428][03 06][00] v2.4.0.4 -> v2.4.10.7 need upgrade.
[00012495][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012629][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00012731][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012802][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012882][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012958][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013004][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013078][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013198][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013258][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013301][01 00][00] v1.22.4095 -> v1.22.4095
[00013337][01 01][00] v1.22.4095 -> v1.22.4095
[00013518][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00013556]Done.
[00015594]Waiting for user confirm...
[00025631]Timeout, start upgrade automatically.
[00025703]Firmware upgrading[1]...
[00025755][11 00] Firmware upgrade start...
[00071946][11 00] Firmware upgrade finished successfully.
[00072189][03 06] Firmware upgrade start...
[00424782][03 06] Firmware upgrade finished successfully.
[00424866][09 00] Firmware upgrade start...
[00478430][09 00] Firmware upgrade finished successfully.
[00478467]Done.
[00478503]Version checking[2]...
[00478594][03 05][00] v34.2.0.9 -> v34.2.0.9
[00478674][03 06][05] v2.4.10.7 -> v2.4.10.7
[00478721][04 00][00] v1.41.0.0 -> v1.41.0.0
[00478834][11 00][05] v1.7.15.1 -> v1.7.15.1
[00478930][12 00][00] v1.10.0.0 -> v1.10.0.0
[00479003][12 01][00] v1.10.0.0 -> v1.10.0.0
[00479083][12 02][00] v1.10.0.0 -> v1.10.0.0
[00479157][12 03][00] v1.10.0.0 -> v1.10.0.0
[00479199][15 00][00] v1.1.2.0 -> v1.1.2.0
[00479297][17 00][00] v1.1.1.7 -> v1.1.1.7
[00479427][17 01][00] v1.0.2.7 -> v1.0.2.7
[00479477][19 00][00] v1.0.8.96 -> v1.0.8.96
[00479517][01 00][00] v1.22.4095 -> v1.22.4095
[00479559][01 01][00] v1.22.4095 -> v1.22.4095
[00479617][09 00][05] v2.13.0.0 -> v2.13.0.0
[00479654]Packet upgrade finish successfully.
[00012028]========== 2016.02.03 10:11:35. boot(15) ============
[00012063]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012102]Packet upgrade start...
[00012143]Packet checking...
[00012187]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012223]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012262]Done.
[00012299]Version checking[1]...
[00012388][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012451][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012502][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012708][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012796][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012876][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012975][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013178][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013221][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013295][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013411][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013476][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013515][01 00][00] v1.22.4095 -> v1.22.4095
[00013556][01 01][00] v1.22.4095 -> v1.22.4095
[00013616][09 00][00] v2.13.0.0 -> v2.13.0.0
[00013656]Packet upgrade cancelled at version checking.
[00012016]========== 2016.02.03 10:16:21. boot(15) ============
[00012051]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012088]Packet upgrade start...
[00012126]Packet checking...
[00012163]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012199]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012234]Done.
[00012270]Version checking[1]...
[00012345][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012405][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012447][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012705][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012793][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012886][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012959][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013034][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013072][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013153][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013279][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013333][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013369][01 00][00] v1.22.4095 -> v1.22.4095
[00013405][01 01][00] v1.22.4095 -> v1.22.4095
[00013453][09 00][00] v2.13.0.0 -> v2.13.0.0
[00013489]Packet upgrade cancelled at version checking.
[00012035]========== 2016.02.03 10:27:19. boot(15) ============
[00012075]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012113]Packet upgrade start...
[00012156]Packet checking...
[00012200]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012241]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012278]Done.
[00012318]Version checking[1]...
[00012402][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012583][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012632][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012743][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00012833][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012925][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012994][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013071][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012028]========== 2016.02.03 10:28:16. boot(15) ============
[00012067]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012180]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012217]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012254]Done.
[00012291]Version checking[1]...
[00012369][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012450][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012494][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012708][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00012794][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012888][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012988][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013088][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013128][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013213][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013334][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013392][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013430][01 00][00] v1.22.4095 -> v1.22.4095
[00013467][01 01][00] v1.22.4095 -> v1.22.4095
[00013513][09 00][00] v2.13.0.0 -> v2.13.0.0
[00013550]Done.
[00015587]Waiting for user confirm...
[00025623]Timeout, start upgrade automatically.
[00025698]Firmware upgrading[1]...
[00025747][11 00] Firmware upgrade start...
[00071845][11 00] Firmware upgrade finished successfully.
[00071883]Done.
[00071920]Version checking[2]...
[00072013][03 05][00] v34.2.0.9 -> v34.2.0.9
[00072088][03 06][00] v2.4.10.7 -> v2.4.10.7
[00072140][04 00][00] v1.41.0.0 -> v1.41.0.0
[00072249][11 00][05] v1.7.15.1 -> v1.7.15.1
[00072342][12 00][00] v1.10.0.0 -> v1.10.0.0
[00072441][12 01][00] v1.10.0.0 -> v1.10.0.0
[00072521][12 02][00] v1.10.0.0 -> v1.10.0.0
[00072721][12 03][00] v1.10.0.0 -> v1.10.0.0
[00072763][15 00][00] v1.1.2.0 -> v1.1.2.0
[00072857][17 00][00] v1.1.1.7 -> v1.1.1.7
[00072978][17 01][00] v1.0.2.7 -> v1.0.2.7
[00073028][19 00][00] v1.0.8.96 -> v1.0.8.96
[00073083][01 00][00] v1.22.4095 -> v1.22.4095
[00073121][01 01][00] v1.22.4095 -> v1.22.4095
[00073188][09 00][00] v2.13.0.0 -> v2.13.0.0
[00073227]Packet upgrade finish successfully.
[00012018]========== 2016.02.03 10:30:17. boot(15) ============
[00012055]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012094]Packet upgrade start...
[00012135]Packet checking...
[00012174]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012212]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012250]Done.
[00012288]Version checking[1]...
[00012381][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012462][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012506][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012702][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012790][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012890][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012990][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013090][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035628][15 00][00] device not detected.
[00035708][17 00][00] v1.1.1.7 -> v1.1.1.7
[00035851][17 01][00] v1.0.2.7 -> v1.0.2.7
[00035912][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035950][01 00][00] v1.22.4095 -> v1.22.4095
[00035989][01 01][00] v1.22.4095 -> v1.22.4095
[00036057][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036095]Packet upgrade failed at version checking.
[00012056]========== 2016.02.03 10:32:07. boot(15) ============
[00012094]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012132]Packet upgrade start...
[00012174]Packet checking...
[00012212]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012251]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012288]Done.
[00012327]Version checking[1]...
[00012396][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012556][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012600][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012717][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012805][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012970][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013056][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013097][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013180][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013301][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013360][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013399][01 00][00] v1.22.4095 -> v1.22.4095
[00013439][01 01][00] v1.22.4095 -> v1.22.4095
[00013500][09 00][00] v2.13.0.0 -> v2.13.0.0
[00013541]Packet upgrade cancelled at version checking.
[00012045]========== 2016.02.03 10:42:10. boot(15) ============
[00012085]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012123]Packet upgrade start...
[00012166]Packet checking...
[00012206]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012246]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012285]Done.
[00012324]Version checking[1]...
[00012407][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012487][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012537][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012727][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012816][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012896][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012971][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013067][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035607][15 00][00] device not detected.
[00035694][17 00][00] v1.1.1.7 -> v1.1.1.7
[00035837][17 01][00] v1.0.2.7 -> v1.0.2.7
[00035898][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035939][01 00][00] v1.22.4095 -> v1.22.4095
[00035978][01 01][00] v1.22.4095 -> v1.22.4095
[00036040][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036080]Packet upgrade failed at version checking.
[00012078]========== 2016.02.03 10:47:34. boot(15) ============
[00012121]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012163]Packet upgrade start...
[00012335]Packet checking...
[00012381]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012427]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012468]Done.
[00012518]Version checking[1]...
[00012621][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012705][03 06][00] v2.4.10.7 -> v2.4.10.7
[00012770][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012905][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013010][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013109][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013211][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013295][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013343][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013429][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013586][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013655][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013698][01 00][00] v1.22.4095 -> v1.22.4095
[00013745][01 01][00] v1.22.4095 -> v1.22.4095
[00013814][09 00][00] v2.13.0.0 -> v2.13.0.0
[00013859]Packet upgrade cancelled at version checking.
[00012560]========== 2016.02.03 12:17:46. boot(15) ============
[00012621]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012669]Packet upgrade start...
[00012713]Packet checking...
[00012759]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012803]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012855]Done.
[00012898]Version checking[1]...
[00012990][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013069][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013152][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013269][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013393][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013472][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013558][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013633][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036177][15 00][00] device not detected.
[00036271][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036403][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036459][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036508][01 00][00] v1.22.4095 -> v1.22.4095
[00036550][01 01][00] v1.22.4095 -> v1.22.4095
[00036643][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036826]Packet upgrade failed at version checking.
[00012594]========== 2016.02.03 12:18:45. boot(0) ============
[00012638]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012691]Packet upgrade start...
[00012739]Packet checking...
[00012786]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012835]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012879]Done.
[00012961]Version checking[1]...
[00013052][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013125][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013218][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013324][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013424][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013524][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013624][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013724][12 03][00] v1.10.0.0 -> v1.10.0.0
[00012581]========== 2016.02.03 12:19:42. boot(15) ============
[00012664]Packet upgrade start...
[00012708]Packet checking...
[00012828]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012870]Done.
[00012911]Version checking[1]...
[00012991][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013072][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013119][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013234][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013319][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013421][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013545][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013680][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036222][15 00][00] device not detected.
[00036302][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036432][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036497][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036540][01 00][00] v1.22.4095 -> v1.22.4095
[00036581][01 01][00] v1.22.4095 -> v1.22.4095
[00036637][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036679]Packet upgrade failed at version checking.
[00013057]========== remo-con disconnect. boot(15) ============
[00013218]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00013268]Packet upgrade start...
[00013321]Packet checking...
[00013368]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013417]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013466]Done.
[00013514]Version checking[1]...
[00013597][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013697][03 06][00] v2.4.10.7 -> v2.4.13.0 need upgrade.
[00013752][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013897][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014011][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014111][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014217][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014326][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014377][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014466][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014586][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014672][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014720][01 00][00] v1.22.4095 -> v1.23.4920 need upgrade
[00014768][01 01][00] v1.22.4095 -> v1.23.4920 need upgrade
[00014832][09 00][00] v2.13.0.0 -> v2.13.0.0
[00014902]Done.
[00016954]Waiting for user confirm...
[00027002]Timeout, start upgrade automatically.
[00027102]Firmware upgrading[1]...
[00039952][01 00] Firmware upgrade start...
[00011727][01 00] Firmware upgrade finished successfully.
[00011787]Done.
[00011837]Packet [C:\P3S_FW_V01.07.0060.bin] resumed, card sn [0x016203e1].
[00011891]Packet vlink 01.07.0060 <-> 01.06.0040.
[00011953]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012004]Version checking[2]...
[00012080][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012160][03 06][00] v2.4.10.7 -> v2.4.13.0 need upgrade.
[00012217][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012345][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012430][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012520][12 01][00] v1.10.0.0 -> v1.10.0.0
[00012626][12 02][00] v1.10.0.0 -> v1.10.0.0
[00012720][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035270][15 00][00] device not detected.
[00035370][17 00][00] v1.1.1.7 -> v1.1.1.7
[00035510][17 01][00] v1.0.2.7 -> v1.0.2.7
[00035716][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035774][01 00][05] v1.23.4920 -> v1.23.4920
[00035825][01 01][00] v1.22.4095 -> v1.23.4920 need upgrade
[00035915][09 00][00] v2.13.0.0 -> v2.13.0.0
[00035982]Done.
[00036036]Firmware upgrading[2]...
[00036206][01 01] Firmware upgrade start...
[00066541][01 01] Firmware upgrade finished successfully.
[00066809][03 06] Firmware upgrade start...
[00338448][03 06] Firmware upgrade finished successfully.
[00338506]Done.
[00338559]Version checking[3]...
[00338650][03 05][00] v34.2.0.9 -> v34.2.0.9
[00338731][03 06][05] v2.4.13.0 -> v2.4.13.0
[00338798][04 00][00] v1.41.0.0 -> v1.41.0.0
[00338931][11 00][00] v1.7.15.1 -> v1.7.15.1
[00339023][12 00][00] v1.10.0.0 -> v1.10.0.0
[00339123][12 01][00] v1.10.0.0 -> v1.10.0.0
[00339224][12 02][00] v1.10.0.0 -> v1.10.0.0
[00339324][12 03][00] v1.10.0.0 -> v1.10.0.0
[00361879][15 00][00] device not detected.
[00361979][17 00][00] v1.1.1.7 -> v1.1.1.7
[00362131][17 01][00] v1.0.2.7 -> v1.0.2.7
[00362195][19 00][00] v1.0.8.96 -> v1.0.8.96
[00362248][01 00][05] v1.23.4920 -> v1.23.4920
[00362307][01 01][05] v1.23.4920 -> v1.23.4920
[00362396][09 00][00] v2.13.0.0 -> v2.13.0.0
[00362447]Packet upgrade failed at version checking.
[00012086]========== remo-con disconnect. boot(15) ============
[00012139]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012193]Packet upgrade start...
[00012254]Packet checking...
[00012304]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012362]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012419]Done.
[00012469]Version checking[1]...
[00012564][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012664][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012721][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012864][11 00][00] v1.7.15.1 -> v1.7.15.1
[00012973][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013073][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013193][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013293][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035943][15 00][00] device not detected.
[00036030][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036172][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036249][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036308][01 00][00] v1.23.4920 -> v1.23.4920
[00036364][01 01][00] v1.23.4920 -> v1.23.4920
[00036429][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036488]Packet upgrade failed at version checking.
[00012872]========== remo-con disconnect. boot(15) ============
[00012927]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012985]Packet upgrade start...
[00013037]Packet checking...
[00013094]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013158]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013211]Done.
[00013263]Version checking[1]...
[00013357][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013438][03 06][00] v2.4.13.0 -> v2.4.13.0
[00013500][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013638][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013731][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013832][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013932][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014032][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036592][15 00][00] device not detected.
[00036688][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036829][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036908][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036961][01 00][00] v1.23.4920 -> v1.23.4920
[00037020][01 01][00] v1.23.4920 -> v1.23.4920
[00037088][09 00][00] v2.13.0.0 -> v2.13.0.0
[00037145]Packet upgrade failed at version checking.
[00012558]========== remo-con disconnect. boot(15) ============
[00012610]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012661]Packet upgrade start...
[00012715]Packet checking...
[00012768]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012818]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012870]Done.
[00012921]Version checking[1]...
[00013025][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013119][03 06][00] v2.4.13.0 -> v2.4.13.0
[00013301][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013419][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013528][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013628][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013728][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013834][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036389][15 00][00] device not detected.
[00036490][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036642][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036705][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036763][01 00][00] v1.23.4920 -> v1.23.4920
[00036814][01 01][00] v1.23.4920 -> v1.23.4920
[00036886][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036940]Packet upgrade failed at version checking.
[00012669]========== remo-con disconnect. boot(15) ============
[00012723]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012773]Packet upgrade start...
[00012828]Packet checking...
[00012883]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012937]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012987]Done.
[00013039]Version checking[1]...
[00013128][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013226][03 06][00] v2.4.13.0 -> v2.4.13.0
[00013284][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013426][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013547][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013649][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013749][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013849][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036408][15 00][00] device not detected.
[00036511][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036651][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036726][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036778][01 00][00] v1.23.4920 -> v1.23.4920
[00036836][01 01][00] v1.23.4920 -> v1.23.4920
[00036906][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036960]Packet upgrade failed at version checking.
[00012203]========== remo-con disconnect. boot(15) ============
[00012257]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012319]Packet upgrade start...
[00012382]Packet checking...
[00012434]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012600]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00012661]Done.
[00012722]Version checking[1]...
[00012817][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012897][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012970][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013097][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013211][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013311][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013411][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013511][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018070][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018186][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018306][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018387][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018440][01 00][00] v1.23.4920 -> v1.23.4920
[00018500][01 01][00] v1.23.4920 -> v1.23.4920
[00018587][09 00][00] v2.13.0.0 -> v2.13.0.0
[00018643]Packet upgrade cancelled at version checking.
[00012189]========== remo-con disconnect. boot(15) ============
[00012252]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012303]Packet upgrade start...
[00012363]Packet checking...
[00012428]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012484]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012535]Done.
[00012591]Version checking[1]...
[00012688][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012769][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012845][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012968][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013077][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013177][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013277][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013380][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035932][15 00][00] device not detected.
[00036018][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036158][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036238][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036288][01 00][00] v1.23.4920 -> v1.23.4920
[00036344][01 01][00] v1.23.4920 -> v1.23.4920
[00036418][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036476]Packet upgrade failed at version checking.
[00012158]========== remo-con disconnect. boot(15) ============
[00012215]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012270]Packet upgrade start...
[00012326]Packet checking...
[00012388]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012451]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012503]Done.
[00012558]Version checking[1]...
[00012646][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012726][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012806][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012926][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013046][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013146][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013249][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013347][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035900][15 00][00] device not detected.
[00036017][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036152][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036216][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036279][01 00][00] v1.23.4920 -> v1.23.4920
[00036340][01 01][00] v1.23.4920 -> v1.23.4920
[00036416][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036477]Packet upgrade failed at version checking.
[00012123]========== remo-con disconnect. boot(15) ============
[00012181]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x016203e1].
[00012230]Packet upgrade start...
[00012297]Packet checking...
[00012358]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012418]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 1).
[00012472]Done.
[00012527]Version checking[1]...
[00012616][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012701][03 06][00] v2.4.13.0 -> v2.4.10.7
[00012783][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012901][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013020][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013116][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013216][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013316][12 03][00] v1.10.0.0 -> v1.10.0.0
[00035868][15 00][00] device not detected.
[00035967][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036106][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036309][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036372][01 00][00] v1.23.4920 -> v1.22.4095 need upgrade
[00036423][01 01][00] v1.23.4920 -> v1.22.4095 need upgrade
[00036507][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036568]Done.
[00038625]Waiting for user confirm...
[00048682]Timeout, start upgrade automatically.
[00048802]Firmware upgrading[1]...
[00048987][01 01] Firmware upgrade start...
[00079332][01 01] Firmware upgrade finished successfully.
[00079392]Done.
[00079453]Version checking[2]...
[00079544][03 05][00] v34.2.0.9 -> v34.2.0.9
[00079619][03 06][00] v2.4.13.0 -> v2.4.10.7
[00079689][04 00][00] v1.41.0.0 -> v1.41.0.0
[00079840][11 00][00] v1.7.15.1 -> v1.7.15.1
[00079934][12 00][00] v1.10.0.0 -> v1.10.0.0
[00080029][12 01][00] v1.10.0.0 -> v1.10.0.0
[00080130][12 02][00] v1.10.0.0 -> v1.10.0.0
[00080229][12 03][00] v1.10.0.0 -> v1.10.0.0
[00102791][15 00][00] device not detected.
[00102891][17 00][00] v1.1.1.7 -> v1.1.1.7
[00103034][17 01][00] v1.0.2.7 -> v1.0.2.7
[00103111][19 00][00] v1.0.8.96 -> v1.0.8.96
[00103178][01 00][00] v1.23.4920 -> v1.22.4095 need upgrade
[00103236][01 01][05] v1.22.4095 -> v1.22.4095
[00103310][09 00][00] v2.13.0.0 -> v2.13.0.0
[00103377]Packet upgrade failed at version checking.
[00012322]========== remo-con disconnect. boot(15) ============
[00012380]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012435]Packet upgrade start...
[00012504]Packet checking...
[00012564]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012623]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012686]Done.
[00012747]Version checking[1]...
[00012838][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012918][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012999][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013118][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013221][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013322][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013421][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013519][12 03][00] v1.10.0.0 -> v1.10.0.0
[00018199][15 00][00] v1.1.2.0 -> v1.1.2.0
[00018285][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018428][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018507][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018568][01 00][00] v1.23.4920 -> v1.23.4920
[00018628][01 01][00] v1.22.4095 -> v1.23.4920 need upgrade
[00018707][09 00][00] v2.13.0.0 -> v2.13.0.0
[00018769]Done.
[00020833]Waiting for user confirm...
[00030893]Timeout, start upgrade automatically.
[00031021]Firmware upgrading[1]...
[00031203][01 01] Firmware upgrade start...
[00061539][01 01] Firmware upgrade finished successfully.
[00061601]Done.
[00061661]Version checking[2]...
[00061762][03 05][00] v34.2.0.9 -> v34.2.0.9
[00061842][03 06][00] v2.4.13.0 -> v2.4.13.0
[00061913][04 00][00] v1.41.0.0 -> v1.41.0.0
[00062082][11 00][00] v1.7.15.1 -> v1.7.15.1
[00062191][12 00][00] v1.10.0.0 -> v1.10.0.0
[00062290][12 01][00] v1.10.0.0 -> v1.10.0.0
[00062390][12 02][00] v1.10.0.0 -> v1.10.0.0
[00062491][12 03][00] v1.10.0.0 -> v1.10.0.0
[00062563][15 00][00] v1.1.2.0 -> v1.1.2.0
[00062644][17 00][00] v1.1.1.7 -> v1.1.1.7
[00062784][17 01][00] v1.0.2.7 -> v1.0.2.7
[00062870][19 00][00] v1.0.8.96 -> v1.0.8.96
[00062935][01 00][00] v1.23.4920 -> v1.23.4920
[00062991][01 01][05] v1.23.4920 -> v1.23.4920
[00063070][09 00][00] v2.13.0.0 -> v2.13.0.0
[00063135]Packet upgrade finish successfully.
What Ipad ios version are you running, I updated to 9.3.1
Heres a link to see whats happening, It actually worked the first time, then from then on it didnt. ( It dosent matter if its inside or way out in the sticks with less interference)
when it does work
when it dosen't
Thanks for your time.
2016-4-4
DJI-Ken
DJI Team
Lett's try again, format the SD card and install the unzipped 1.7 BIN file again and after it's finished then post the hidden file. don't keep trying it.
Also, I'm not seeing the module 8. Usually it says module 8 and module 15 Device Not Detected. Regardless, if it does not work that it will have to come in for a warranty repair.
It was never crashed correct?
2016-4-5
Lynx.1
I have  found a SITE with all the OLD Go apps on it .... I have tried 5 of them and the last one showed me I was connected to a insaron 1.... holy shit I only have a Phantom 3-4k
So following the Go app and letting it up date my RC and drone has told the drone its 50% INSPIRE & 50% phantom 3-4k... how did I fiend this out ...
I poked round in the android files and found the list of updats... hold on I will post all the firmware updates..... so you can see
component_upgrade_date.json
component_upgrade_list.json
component_upgrade_list_br.json
list.json
upgrade_component_UpgradeInspireOneComponent.json
upgrade_component_UpgradeInspireOneRcComponent.json
upgrade_component_UpgradeP34kcomponent.json
Now this is for a PHANTOM 3-4k .... if yous like to see the full listing of the sites the files came from I can do that but then some novice might try flashing there stuff and funk things up more ...
So DJI-Ken if youd like to PM me I will send you a full copy of me files ....
some one give me a flash to send the RC & drone back to factory and I will be happy to stop baging the crap out of ( support and will not need to send my drone ( NEW ) back to the shop 2.365mils away
2016-4-5
sandmarkcontrac
Ken
Hi, This has never been crashed, and I really look after my stuff.
Ive copied and installed again, I had to do it twice cause after the first time it didn't even generate a hidden log ( I then used a faster SD card), anyway here are the results.
[00264520]Done.
[00265629]Done.
[00012252]Done.
[00013556]Done.
[00478467]Done.
[00012262]Done.
[00012234]Done.
[00012278]Done.
[00012254]Done.
[00013550]Done.
[00071883]Done.
[00012250]Done.
[00012288]Done.
[00012285]Done.
[00012468]Done.
[00012855]Done.
[00012879]Done.
[00012870]Done.
[00013466]Done.
[00014902]Done.
[00011787]Done.
[00035982]Done.
[00338506]Done.
[00012419]Done.
[00013211]Done.
[00012870]Done.
[00012987]Done.
[00012661]Done.
[00012535]Done.
[00012503]Done.
[00012472]Done.
[00036568]Done.
[00079392]Done.
[00012686]Done.
[00018769]Done.
[00061601]Done.
[00012184]========== remo-con disconnect. boot(15) ============
[00012237]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x0014db2f].
[00012293]Packet upgrade start...
[00012352]Packet checking...
[00012404]Packet vlink 01.07.0060 <-> 01.06.0040.
[00012461]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00012515]Done.
[00012568]Version checking[1]...
[00012665][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012745][03 06][00] v2.4.13.0 -> v2.4.13.0
[00012804][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012925][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013045][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013259][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013359][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013459][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036015][15 00][00] device not detected.
[00036115][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036261][17 01][00] v1.0.2.7 -> v1.0.2.7
[00036335][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036386][01 00][00] v1.23.4920 -> v1.23.4920
[00036444][01 01][00] v1.23.4920 -> v1.23.4920
[00036515][09 00][00] v2.13.0.0 -> v2.13.0.0
[00036575]Packet upgrade failed at version checking.
[00012751]========== remo-con disconnect. boot(15) ============
[00012805]Packet [C:\P3S_FW_V01.07.0060.bin] detected, card sn [0x016203e1].
[00012871]Packet upgrade start...
[00012937]Packet checking...
[00013000]Packet vlink 01.07.0060 <-> 01.06.0040.
[00013067]Record vlink 01.07.0060 <-> 01.06.0040 (flow = 0).
[00013130]Done.
[00013196]Version checking[1]...
[00013283][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013399][03 06][00] v2.4.13.0 -> v2.4.13.0
[00013467][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013620][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013708][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013808][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013908][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014008][12 03][00] v1.10.0.0 -> v1.10.0.0
[00036574][15 00][00] device not detected.
[00036669][17 00][00] v1.1.1.7 -> v1.1.1.7
[00036909][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036966][01 00][00] v1.23.4920 -> v1.23.4920
[00037025][01 01][00] v1.23.4920 -> v1.23.4920
[00037109][09 00][00] v2.13.0.0 -> v2.13.0.0
[00037166]Packet upgrade failed at version checking.
========== 2014.01.01 00:04:24 remo-con disconnect======
Packet: P3S_FW_V01.06.0040.bin
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2016.02.03 10:11:35 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.02.03 10:16:21 =====================
Result: Abort.
========== 2016.02.03 10:27:19 =====================
========== 2016.02.03 10:28:16 =====================
Upgrading ...
Result: Success.
========== 2016.02.03 10:30:17 =====================
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.02.03 10:32:07 =====================
Result: Abort.
========== 2016.02.03 10:42:10 =====================
Result: Failed.
========== 2016.02.03 10:47:34 =====================
Result: Abort.
========== 2016.02.03 12:17:45 =====================
Result: Failed.
========== 2016.02.03 12:18:44 =====================
========== 2016.02.03 12:19:41 =====================
Result: Failed.
Packet: P3S_FW_V01.07.0060.bin
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Abort.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Success.
Result: Failed.
Result: Failed.
2016-4-5
pauldharmaratne
Downgrade to Go 2.6.1 and appears to work as before. It has to be the Go Appp 2.7
2016-4-7
pauldharmaratne
Downgraded the Go App to 2.6.1 and now receiving video as before. Must be the ver 2.7.1 thats causing the video problem. DJI should look into this.
2016-4-7
martinpamor
pauldharmaratne Posted at 2016-4-7 13:34
Downgraded the Go App to 2.6.1 and now receiving video as before. Must be the ver 2.7.1 thats causin ...
Just upgraded the latest firmware for the aircraft, all went ok.  As I am using the Tab 3 8.0 with the 2.6.1.DJI Go app, I found that the firmware upgrade for the transmitter would not install.  It seems that the latest transmitter upgrade is done through the latest DJI Go App that I do not want as live video feed as we know doesn't work.  To get round this I have installed the latest DJI Go app on my S4 Mini phone and then the transmitter firmware upgrade installed from that.  Then it was just a matter of connecting the Tab 3 8.0 up again with the DJI Go v2.6.1. and all works fine and with live video feed.
Martin
2016-4-9
superik.nice
Flight distance : 184058 ft
martinpamor Posted at 2016-4-3 05:16
A lot of hard work there Eric, and it ends up I would imagine being very frustrating for you.  Wou ...
hello Martin,
I will not go back to KitKat on my Samsung Tab 3 ... in fact I've just bought a Xiaomi MiPad 2. As soon as I receive it, I will test it and hope it will be ok
The recommanded tabs are "old" . I would buy a new tab (not a second hand), i was not able to find the Xiaomi MiPad "1" (or Samsung Tab S "1" ).
The problem with samsung Tab 3 seems like a graphic card driver problem on computer ... maybe the graphic chipset is not supported by DJI Go ...
For now, I use my Samsung Note 4 phone (but the screen is "too small" for controlling the drone I think).
DJI support team has tried to help me (with tab 3 no live feed issue), I've done serveral tests but still the same result.
I've tested the last firmware and dji go app, on the tab 3, still the same problem.
2016-4-11
martinpamor
superik.nice Posted at 2016-4-11 13:28
hello Martin,
I will not go back to KitKat on my Samsung Tab 3 ... in fact I've just bought a Xiao ...
Hello Eric,
thanks for the information.  Yes I think we will go round and round in circles on this problem.  For me the Tab 3 8.0 works well with Dji Go  v2.6.1 and also on the latest firmware for aircraft and transmitter.  My concern would if I changed to another tablet which might work at the moment on the latest DJI Go App but then stops working again on future revisions.  The only way to insure against this from happening might be to choose a device supported from the recommended DJI list but I find that list limited for 8 inch and greater screen sizes.  I also am not into apple devices so it limits me even more to what is on the recommended list.  I might though take a chance and choose a device not on that list that does work with the latest Version DJI Go App and hope it continues to work on later revisions.  Also I and others cannot keep affording to keep changing tablet devices so I would like to get it right the first time.  Do we know of any devices of 8 inch screen or more that will work well with the latest DJI Go app?  I know my Samsung S4 mini works well with the latest DJI App but the screen is too small.  In addition that device isn't on the recommended DJI list.  Do DJI recommend more SIM type devices, ie so that on location, the maps can be brought up on screen?  Personally I don't think that to be necessary as, if that function is needed either the map can be loaded up at home or with the purchase of a wifi dongle that would certainly load up maps in any sim signal area.  My final thoughts are do Litchi have a recommended tablet list or do they go along with DJI's? I have had a look on the Litchi site but cant find any information on this.  I have also started a new thread "Unsupported Android Devices that work on V2.8.1" to see if others can share their information on what does and doesn't work in the Android device world.  Anyway they are just a few thoughts to ponder.
Martin
2016-4-11
superik.nice
martinpamor Posted at 2016-4-11 17:26
Hello Eric,
thanks for the information.  Yes I think we will go round and round in circles on thi ...
There is no recommanded/supported Android devices for litchi. You can tried during 2 hours the App, if it s not ok you can ask for refund. So if you are new with the APP, it's ok.
I haven't found any supported android device list on other third party app.
I will keep you informed as soon as I received my new tab (Xiaomi), so it s ok : great, I could use my drone in correct condition (with a 8 inches screen)... anyway anytimes there will be a Drone or DJI Go app upgrade, I will pray the QuadCopter Saint (in order the new firmware still works ;) ).
Eric
2016-4-11
thetriplep
Same here no video feed since the  upgrade
2016-4-11
martinpamor
thetriplep@hotm Posted at 2016-4-11 16:51
You could go back and try DJI Go v2.6.1, I know its not the complete answer but live Video works for me.
2016-4-11
superik.nice
Hello,
I've just received my new Xiaomi MiPad2. GooglePlay is not installed by default, after following a tutorial : http://techtablets.com/2015/12/h ... re-on-the-mi-pad-2/ , I was able to install the last version of DJI GO ... and fortunately I've got live feed
I will tried the stability of the tab tomorrow, anyway it seems to be a good alternative choice (8 inches, not expensive tab) too Apple tablets (for Phantom control).
Eric
2016-4-16
superik.nice
hi, Ive tested several mode : point of view, normal mode , during 2 batteries (35 min ) - everythings was ok. I ve not lost signal. I havn t checked if tablet gps was ok anyway. from now I m satisfied of it (instead of samsung tab3). Eric
2016-4-17
barret.henry
Newbie here my p3A was asking for 3 firmware update did the 1.8.80 but it's still a king for camera and remote update?!?
2016-4-17
Gary England
Flight distance : 54669 ft
DJI-Ken Posted at 2016-3-17 05:31
I updated about 10 aircraft in the last few days, all went fine.
DJI-Ken
I accidentally had the s-1 in the lower position when i started the upgrade.  The upgrade failed I'm not sure why.  I also formatted the drive and reloaded the firmware file.  The result file reads
========== 2014.01.01 00:01:07 remo-con disconnect======
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:05:15 remo-con disconnect======
Upgrading ...
Result: Failed.
When I turn on the aircraft there is a loud alarm, I can connect my Iphone and the RC but it gives me no option to try to reload the firmware.  Is there a way I can load it from my laptop?
Any advise would be greatly appreciated.
Thanks,
Gary
12566553634
2016-4-17
prairieboy
My buddy and I both have P3A and after the update we are both having choppy live video signal and can only fly 1300m with clear line of site without any obstructions, he was actually having issue at 500m. And this was flying from the same location I always do, definitely a negative difference since the update.
2016-4-17
kirk2579
Flight distance : 37415 ft
Jkeller84 Posted at 2016-3-17 11:27
Negative. My 2 P3Ps are working flawlessly after the update. Never had any trouble with either of  ...
+1
2016-4-17
kirk2579
FAS1 Posted at 2016-4-4 21:51
FWIW
I hope you realize that link is NOT  a DJI site.
It is a private guy running his website with info and hints etc.
also for 200 the NVidia shield k1 can not be beat,
not on any list but runs my p3p and go 2.7.2 fine
2016-4-17
FAS1
I do and I owe DJI Ken an apology. DJI Ken, I apologize.  And the Acer Iconia Tab 10 works well now, after installing the app 'ShutApp'. Everything is right with the world again. Except what I'm hearing, that the latest  FW version blocks using Litchi with 3rd party batteries. Still haven't gotten verified confirmation either way, though.
2016-4-17
Mike_fnq
Flight distance : 5623 ft
nigelw Posted at 2016-3-17 23:59
Does it fix anything?  Is there a point to the "upgrade"?
^^^What he said^^^
I'm still on 1.4 and think I actually have more functionality than those that have upgraded (NFZ etc)
2016-4-17
1234
