New Mavic 2 Pro/Zoom Firmware Released (07/07/2020)
12345
47242 195 2020-7-7
cool88
Malaysia
anto noprianto Posted at 7-16 02:01
so sad after the upgrade my mavic 2 pro the range between aircraft and the remotw is only 30 cm, and then the remote had notif No Rc signal, im also downgrade and upgrage repeatly but the result is the same...please DJI help me
Same problem here. Downgraded the software, relinked RC....any one found a solution?
2020-8-25
smirnoff9969
Flight distance : 582776 ft
Croatia
I returned from my trip, had few flights no bugs or anything annoying...
2020-8-27
DH_Pilot
Flight distance : 3301621 ft
Slovakia
cool88 Posted at 8-25 23:51
So are you now in the state where you are loosing signal even when you downgraded firmware back to 510?
2020-9-2
STST
Flight distance : 734882 ft
Israel
also same issue, after the Firmware Upgrade ,
the signal lost after few meters.
- downgrade Firmware not fix it.
- Re-link the remote & aircraft not fix it - Different locations & good weather same issue
The M2P are now Unusable with this problem.
2020-9-6
DH_Pilot
Slovakia
STST Posted at 9-6 04:27
can you try manually switch different channel from 2,4ghz then from 5,8ghz... shuffle them multiple times if that will do something?
2020-9-6
STST
Israel
DH_Pilot Posted at 9-6 06:25
I wish I could, frequency 5.8 is locked for use in the app, in our country, frequency 5.8 is for military use only.
Except for indoor use (it's funny and silly I know, but it's the truth)
2020-9-6
DH_Pilot
Slovakia
STST Posted at 9-6 06:49
And are you able to switch between 2,4 ghz channels? Those are the lower ones like 1 - 13.
2020-9-6
STST
Israel
DH_Pilot Posted at 9-6 08:14
Yes, but no change.
Its look like the transmitter works at low power.
2020-9-6
DH_Pilot
Slovakia
STST Posted at 9-6 09:02
Yes, but no change.
That is very strange and disapointing. Then only thing I could think of is to restore factory defaults via DJI Assistant in PC, but DJI Assistant for Mavic 2 doesn't have this option, but version for old Mavic Pro - DJI Assistant have it. I already tried to do reset to factory of Mavic 2 via older DJI assistant via PC. I personally think it is low chance it will help but that is last think I could advice.
2020-9-6
STST
Israel
DH_Pilot Posted at 9-6 09:15
I already try this.
2020-9-6
DH_Pilot
Slovakia
STST Posted at 9-6 22:57
I already try this.
Ok then I'm afraid that only DJI could help you either by releasing some fixed FW or providing some kind of fix via beta firmware or so. Or in worst case by sending drone in for service.
2020-9-7
STST
Israel
DH_Pilot Posted at 9-7 00:14
Yes, but it's frustrating, I have to pay for the repair, because DJI has released a bad firmware version.
2020-9-7
fans1f690efe
RK7dronzy Posted at 7-8 07:09
Sorry but what good is this update. Encourage people to fly even further away illegally in eu, uk and usa, or will that create more crashes when they run out of power. Never had any issues with the gimble. Now the batteries will start ruuning flat after 2 days which means my third batt will always need recharging , if using one a day as i do. Never had problem with controller in cold weather. Where is the 4k at 60 frames a sec and better resolution in the hyperlapse. It seems to me that dji have ignored all the complaints in this forum over the last year. Rant over.
I agree with you ,  my gimbal was working fine before the upgrade now it doesn't respond to the remote properly.  Why drain the batteries after two days
2020-9-9
Dorianbz
Bimnomercy Posted at 7-7 21:56
Thank you DJI for this firmware update, but I don't see anything about the new French regulations on electronic reporting.
I remind you nevertheless that since the beginning of July, no mavic 2 newly purchased can legally fly in France because of the absence of electronic reporting. This obliges new buyers to equip their drone with an additional module worth at least 200 €.
He has a thread on the subject. Apparently they're working on it.
It's technically possible if they make the effort to take an interest in it.
https://forum.dji.com/forum.php?mod=viewthread&tid=205582
DJI is in contact with the French authorities concerning this new regulation, and all UAVs equipped with the OcuSync 2 protocol should benefit from a firmware Update that will enable the UAV to transmit the signal frame itself without any external device (i.e. Mavic 2 series, P4 Pro V2.0, P4 RTK, P4 Multispectral, 200 V2 / 210 V2 Matrix).
The other older UAVs (Mavic Air 1, Mavic Pro 1, P4 Pro v1 / Adv. , P4 standard, Inspire, ...) will require the purchase of an external signal box to be fixed on the UAV.
To recap we're talking probably about a WiFi beacon frame -attached with Vendor Information Element (ID 221)- and a JSON payload {"1":<Protocol Version>,"2":"REGISTERED SERIAL NUMBER","4":<Current latitude in decimal Degrees>, "5":<Current longitude in decimal Degrees>,  "6":<AMSL in meters>, "7":<AGL in meters (instead of AMSL)>, "8":<Launch latitude in decimal Degrees>, "9":<Launch longitude in decimal Degrees>, "10":<True air speed in m/s>, "11":<True heading in degrees>}
Update :
I found an article that says that a system was implemented in the last update.
I don't know if it's 100% compliant.
Here the link (in french sorry)
https://blog.studiosport.fr/dji-mavic-2-pro-systeme-identification-a-distance/
2020-9-17
CanonMax
Flight distance : 8953215 ft
Well... after reading all comments in this link I hesitated to update my Mavic 2 Pro and the standard controller...
But today I did.... Connected the Mavic 2 to my PC, started the latest DJI Assistant for Mavic and WAITED until the screen stated "update successful" ... during the update the Mavic 2 rebooted 2 or 3 times... JUST WAIT when this happens!!
After that I connected the Remote Controller... and that went well too... You just need to WAIT and not touch the Mavic 2, the Remote or the Cable...
After that I connected my iPad to the Remote Controller, re-booted the Mavic and (indeed) noticed that a few things like MAX FLIGHT DISTANCE were changed and that I needed to re-activate the switch in order to use SPORT and TRIPOD mode... I also inserted my two other batteries and they had to be updated as well.
All fine up to this point....
Then I went out to test this new firmware... went to one of my fields... connected everything and I had not a slight problem... everything worked FINE... Stable connection, great video-feed all as usual...
Take care, fly and update safe...
Max
2020-9-20
STST
Israel
Update:
I had to replace the mainboard,
That cost me 410$.
DJi - Thanks for nothing.
2020-9-22
Matthew Dobrski
Flight distance : 1831050 ft
STST Posted at 9-22 11:43
Update:
That cost me 410$.
Did you replaced faulty mainboard by yourself?
2020-9-27
STST
Israel
Matthew Dobrski Posted at 9-27 15:10
No,
the repair was done at the store where I bought it.the difference in price, I preferred to repair in the store.
But from watching videos on YouTube,
In my opinion with good hands, with the right tools you can replace yourself.
2020-9-29
S.J
Flight distance : 322454 ft
Kuwait
this distance update is for long flight plan routes where you could take a bit the M2P further without any transmission loss during  shooting
2020-10-3
djiuser_pFsgWZyTlH5y
Thanks, this is helpful
2020-10-5
sica
Flight distance : 679 ft
Israel
you will miss the pro-1 mavic. He also had small problems at first but they were solved and it turned out to be an almost perfect drone! I would not change MAVIC-PRO on any new product ...
2020-10-5
Bokstas
Lithuania
After this update, I started to get "control stick error" and "Imu calibration error". I went to adjust these things, but it comes up again and again (time to time), but for the last updates in never come up for years!! That's annoying. The app also when traveling abroad asks to enter pin code sent by SMS (to validate fly safe).. which never have been delivered (((
2020-10-7
sarafox
Droning 24/7 Posted at 7-9 06:13
Not to derail this thread, but since the topic includes an increased flight distance 8km -> 10Km (FCC) which can increase flight times.............
Dji spec is a 59.29Wh lipo battery....So lets say a 60Wh batt to make things easier?
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
آموزش سئو
2020-10-11
cool88
Malaysia
DH_Pilot Posted at 9-2 01:10
Yes i downgraded problem still persist. Totally cant fly at all.... this is totally disappointing from DJI BRICK my MP2 zoom! Is there any recourse  from DJI to compensate....very disappointing
2020-10-13
cool88
Malaysia
Update:
That cost me 410$.
Your replace the controller mainboard or the  drone ? Thanks
2020-10-13
STST
cool88 Posted at 10-13 22:05
only mainboard
2020-10-20
skylarkeast
10 Kilometers away and no power to return home. This would have to be a preprogrammed flight, yes?
2020-10-28
bernardren07
Flight distance : 48504 ft
Singapore
Hi. Should update firmware or wait? Long time no use for drone due covid not allow. I seen some people few problem latest firmware.
2020-10-30
Just a dude
Oracle Miata Posted at 7-7 11:20
I assume this firmware won’t work with the Smart Controller?
Why would you assume that? Anyways yes it works with the smart controller(proud papa of one).
2020-12-18
Just a dude
cool88 Posted at 10-13 20:10
That’s terrifying
2020-12-18
fans871e4f7f
Flight distance : 35098 ft
I’ve tried multiple times to upgrade my firmware, but I get a failed to update message. I’ve tried the dji go 4 app and the assistant 2... Anything you can re recommend to solve the problem? Thanks.
2020-12-31
djiuser_K1X7E0iqS7gl
Brazil
fans871e4f7f Posted at 2020-12-31 00:34
Hi,
which error?
Before updating, reset the drone settings to factory settings.
see if it resolves
2021-1-2
Oracle Miata
Flight distance : 3759829 ft
Just a dude Posted at 2020-12-18 09:57
Because back in June when I posted this, the SC was on a lesser version of GO 4.
2021-1-6
Felix Le Chat
Flight distance : 1348 ft
fanse3badb5d Posted at 2020-8-12 06:00
Can still be flown as a legacy drone,  so your not actually correct
.... until 2022... after which your "legacy" drone becomes obsolete and faces the greatest degree of restrictions. Try arguing the toss with the Civil Aviation Authority.
2021-3-9
MeAtHome
Flight distance : 84104 ft
Switzerland
Good day
Could DJI clean up the Mavic 2 documents? There are two release notes available, but non of them contain the 0770 firmware
2021-7-26
MeAtHome
Switzerland
Well, some cleaning was done, but not finished...
2021-8-26
12345
