Forward and downward vision sensor calibration errors
12
53693 73 2016-4-3
JockC
Flight distance : 459416 ft
WOLF71 Posted at 2017-2-24 13:49
Hi, I'm having the same problem!!!
all happened after I did the last update.
started to appear the vision sensor calibration error.
Same here. I also have been getting the Forward and downward vision sensor calibration errors since installing the latest firmware but only with the initial power on for the day.  After turning the drone off and on (sometimes twice), the message disappears and flights take place with no issues. Subsequent flights after a battery change also take place without the message appearing. The forward and downward sensors work perfectly.
I have done the following in an effort to remove the problem:-
1. Reloaded the firmware using DJI Assistant 2  (V1.0.9) -success
2. Successfully recalibrated the sensors using DJI Assistant 2 (twice).
This problem only started occurring following the most recent firmware update and, as above, the sensors work perfectly once I've turned the drone off and on again.
I'm have no doubt that DJI is aware of the problem and very much hope that a fix will be included in a future firmware update.
2017-3-7
Feiky
Flight distance : 932717 ft
x1War Monger1x Posted at 2017-2-13 18:24
Mine doesn't show that stuff. I only have firmware and black box and those are the only two things on the left hand side. The only other thing that I can think of is that I needed to download again and it came up the same exact way the second time. So now I am thinking that it might be a problem with the programming of the mavic itself. I even reloaded the firmware to see if that might make a difference and it didn't.
HI there, you may already have solved this one, but when connecting to the RC, I noticed this as well. Try connecting the PC directly to the mavic with the usb - this worked for me.
2017-3-17
fansa84fe8a4
Flight distance : 3 ft
For those having an issue, are you calibrating on a glossy screen (i.e. Apple Thunderbolts/Retinas)?  Glare can be an issue with those.
2017-3-17
fans26ff39c1
Flight distance : 1152 ft
Hi, i have the same problems,"calibrate vision sensor" i try to calibrate from djigo4 without successfully.. then,i try to update the firmware from djiassistent2 but when I try to calibrate from pc the app is locked before the 3 steps to calibrate... please help me.
2017-3-31
seannyboyng
Malaysia
hi, i am having the same problems with calibration. Just received my Mavic yesterday and the error popped up last night. Been trying to calibrate it using DJI Assistant 2 but it the calibration either fails after calculation or the screen freezes during one of the dotted screens. Really need to use my Mavic tomorrow for a shoot. Please help.
I just tried to refresh the Mavic's firmware using DJI Assistant but it said Upload Error.
I have already tried changing my screen resolution to 1600x900
2017-6-6
Indonesia
Same problem here.
Until i connect my laptop to tv trough hdmi port.
The dot is there, calibration is there, but the result still fail.
When i choose recalibrate, there is no dot like 1st time.
Why this upgrade bring so much pain this time?
2017-8-18
Aardvark
Flight distance : 384432 ft
@putrawhisnu Posted at 2017-8-18 16:02
Same problem here.
Have you a monitor that you could connect to laptop via DVI or VGA ? I've always had success using a monitor, and failed the once I tried with my laptop screen.
Or perhaps borrow or commandeer another PC for a short while ?
2017-8-18
Wpgubaru
Flight distance : 254646 ft
I had a issue where I couldn't do calibration, when I got a new gaming monitor it worked. Could be the type of monitor.
2017-8-18
F.KOK
Flight distance : 19037933 ft
Namibia
Aardvark Posted at 2017-8-18 16:15
What I discovered once is that when it is to light in the room the sensors struggle to see the blue on the laptop, after I closed the curtains and it was darker, it calibrates fine. Try that.
2017-8-19
Osee
Flight distance : 530758 ft
I spent hours trying all the fixes in this forum - i tried two different windows 10 machines and then booted to a win 8.1 and nothing worked - finally i installed win 7 on one of the hard drives ... shazam !
2017-8-24
user9ed8f94b8e
Russia
We are currently using 4  X P4Pros for a marine mammal monitoring project. Over the past 2 months, almost 200 full flights were made. Equipment is superb, video and photo quality awesome. Though since last week the drones are urged to calibrate the Vision system. I downloaded DJI assistant 2 ( https://dl.djicdn.com/downloads/ ... sistant+2+1.1.0.exe) but am prompted  to reboot the aircraft. I deleted and reinstalled  Assistant 2, and checked the drivers - which seem the latest, or most recent.  Yesterday the camera froze and I had a permanent still image on my iPad. I lost maps and all navigation controls. My spotter guided me back to shore, luckily we were not too far out. Today, I flew with a Samsung Tab2, my navigation map disappeared, luckily the camera kept working and I could find my way back to shore. My questions : 1) Is this freeze related to the necessity to calibrate the Vision system?  2)  Can we just shut-off Vision as we are mainly flying over sea with no obstacles? 3) How to get the right version of DJI Assistant 2 :  we run Windows 10 on our computers . Really would appreciate your advise, as we still have a month work left and we already can't miss the Phantoms :-)  Thanks!
2017-9-3
lannes
Flight distance : 4465 ft
http://www.dji.com/phantom-4-pro/info#downloads
I believe the latest DJI Assistant is version  v1.1.2-2
There is also a new DJI Go4 app version 4.1.9 for IOS released today
I don't think the vision system recalibration request has much to do with your display issues, the vision system is used for obstacle avoidance.
Screen issues relate more to signal quality and interference. I guess if your in the ocean interference won't be an issue, so it's signal quality are you using 2.4 or 5.8ghz
Did you try rebooting the app when you lost your camera view ? that is exiting out of the FPV back to the front DJI Go4 screen and  then entering back in.
On the Tab 2, did you loose both the AC position and maps or just the maps, did  the AC icon stay on the blank screen, did you cache the maps locally before flying ?
2017-9-3
Normn8or
Flight distance : 1466611 ft
OK i'm speechless !!!!!!!!!!!! But,,,,,................. Boy Do i have  A crapload to say eh". Hmmmmmmm
2017-9-3
Strannik Wolkov
Russia
lannes Posted at 2017-9-3 02:07
Hey Iannes, we were having internet issues here - sorry for the delay
Thanks for the link, I have this version of DJI Assistant but it constantly suggest to reboot the drone. I have tried to install it on a Windows 8 computer, but that seems not to work.
Signal ql. 2.4 ghz.   I did not reboot the app. On the Tab2 only the map window disappeared, the main screen with video and all icons were visible. I did not cache the maps before flying. After refreshing/updating the problem disappeared and I flew both on the iPad and Tab2 without loss of signal or freezes. I did not manage however to calibrate the Vision system.
Working on that now.
2017-10-4
lannes
Strannik Wolkov Posted at 2017-10-4 00:46
I think windows 8 has a "driver signature enforcement function that prevents loading drivers that are not digitally assigned.
I had the same reboot problem when calibrating my mavic vision system on windows 10, apparently the DJI vision drivers are not digitally assigned and cannot be loaded, hence the DJI Assistant 2 in the vision calibration process asks for the AC to be rebooted.
You need to turn off the windows 8 driver signature enforcement by following steps 1 - 9  on this link. once you go through this process and the computer restarts you should be able to run the vision calibration as normal after reopening the DJI Assistant 2 and turning on the AC.
https://learn.sparkfun.com/tutorials/disabling-driver-signature-on-windows-8/disabling-signed-driver-enforcement-on-windows-8
Please note the turning  off  of the driver signature enforcement is temporary so when you reboot the pc, it will be reset and you won't be able to do the vision calibration again, you will need to turn it off each time you want to do it.
2017-10-4
Aardvark
Latest version of DJI Assistant 2 is V1.1.6, available from Here
Edit:- I have had no problems at all installing and calibrating VPS using this on Windows 10.
2017-10-4
Strannik Wolkov
Russia
lannes Posted at 2017-10-4 04:18
Thank you Iannes for your elaborate explanation.
Will try this definitely and get back to you.
I should be able to find a similar disabling procedure for Windows 10. Or use the latest version of Assistant as just provided.
2017-10-4
Strannik Wolkov
Russia
Aardvark Posted at 2017-10-4 04:29
Latest version of DJI Assistant 2 is V1.6, available from Here
I have currently V 1. 1.2-2  V01.04.0602. Many thanks for the link to the latest version, I'll try it right now.
Hope this works.
2017-10-4
lannes
Strannik Wolkov Posted at 2017-10-4 14:05
Windows 10 instructions to turn off driver digital signature
http://windowsreport.com/driver-signature-enforcement-windows-10/
2017-10-5
Jim 100
Flight distance : 176535 ft
I am encountering the forward and downward sensor problem as well as more agressive control. All I know is it was fine before the latest update. They want me to send it in but I’m thinking about waiting for a new firmware release to see if that fixes it. I had to purchase a new Mavic to complete a job I was booked to do. I have reinstalled the assistant and updated numerous times with different computers from my MacBook Pro to a dell precision workstation with no success.
2017-10-14
fansccce94cc
Flight distance : 14675 ft
Same problem here.... I was very high on DJI but becoming a bit disgusted with all this.... changed nothing....downloaded nothing and getting “downward vision sensor  calibration error” message.... flew it anyway and had no problems but so annoying.....
2017-12-27
Toorboy
Flight distance : 657382 ft
I deactivated my downward sensors as I never use them
and it always has the warning about the downward sensor error and re-calibrate
total pain lol
2017-12-27
Aardvark
Toorboy Posted at 2017-12-27 08:00
total pain lol
And have you calibrated anything ?
There is a calibration tool for the vision sensors in DJI Assistant 2. That may help even if you have them deactivated.
2017-12-27
Toorboy
Aardvark Posted at 2017-12-27 08:17
hi Aardvark I calibrated the bird when I first got it
but never tampered with it since. does it need calibrated if
you turn them off? I will have a look and report back
2017-12-28
Aardvark
Toorboy Posted at 2017-12-28 00:14
Well although you might deactivate them (the 'visual' sensors) I believe that the ultrasonic sensor in the base might still come into play.
Worth a try anyway.
And perhaps IMU if it's not been done for a while :-)
2017-12-28
TSKorba
India
For forward vision sersor calibration error  = https://www.youtube.com/edit?o=U&video_id=-q9x9YBeR1E
2018-6-18
TSKorba
India
adkornelsen Posted at 2016-5-4 17:34
I've had the same problems ever since I updated to the latest firmware. i don't know what to do.  I also noticed when I have these problems the firmware version says "unknown" yet when it randomly decides to work it tells me I'm running the current verison.
2018-6-18
TSKorba
India
evgenij911@mail Posted at 2016-6-25 10:54
friends, why I do not have to calibrate button ??? how to calibrate for each flight if there is no button?
[view_image][view_image]
2018-6-18
djiuser_K2u8VuvMIJ8y
Pakistan
i've got the issue when i try to calibrate vision sensor after the calibration i've got an error says calibration failed i try 20 times but same error pops up plz help me with that...
2019-3-28
Pakistan
2019-3-28
fans1e7b4df6
Re:vision calibration. My phantom 4 is fresh back from DJI drone doc because after so many failed attempts at upgrading firmware I decided to pay and let the experts do it.
On its return all the boxes were ticked, everything working fine and drone had been and still is "in good working order"
First flight, no error warnings before takeoff but then what do I see on landing...? "Vision calibration error"...pfffff
Honestly, it's just one thing after another. I intend to ignore this warning for a while because experience has taught me that they sometimes go away.
2019-5-6
ATJ
Flight distance : 17736 ft
fans1e7b4df6 Posted at 5-6 06:01
Like many, I have tried calibrating my P4 on a computer screen with 1920x1080 screen resolution many times to no avail. So I set my screen resolution to 1680x1050 and it worked the first time. I don't think the vision sensors are able to see a 1920x1080 resolution.
2019-7-2
fans3a8d2f29
i am able to get as far as the calibration plain white window but the dots never appear anyone got any idea why thanks yan
2020-11-8
fans3a8d2f29
after trying numerous times on MAC i tried my windows laptop and hey presto worked first time you need to sort it out DJI
2020-11-9
12
