DJI's fast analysis of damages
12345
6756 174 2017-1-31
RedHotPoker
Flight distance : 165105 ft
Beux Posted at 2017-2-17 15:26
Thanks.  Which one will make my Phantom 4 flip over and fly upside down into the ground?
You have a slightly different method of shutting down your Phantom 4 now.
But doing  a CSC while the drone has already landed, can often give it reason to react most unfavorably.
Those stick commands are most unusual for regular flight direction, so it was likely chosen being an unusual stick motion, under our normal flying circumstances.
RedHotPoker
2017-2-17
WA5TEF
Flight distance : 124672 ft
Mattcoq Posted at 2017-2-17 04:26
There are two case scenarios to my knowledge depending on which program you use to fly your drone :
1. DJI Go
Hey MattC:  Not sure what you mean, here is what I did.  I found HealthyDrones and uploaded my total apps to it then when I looked for the crash date, it was not there, along with probably 35 more.  They are not on my iPad or iPhone either.  No one has yet explained how the log files can't be saved.  I am waiting on DJI to let me know now.  At least they answered my email I sent about 4 hours ago.  I'll let everyone know when they actually do reply.
Thanks,
Jim
WA5TEF
2017-2-17
WA5TEF
24ctDrone Posted at 2017-2-17 14:59
You do you man.  I had an issue with an Inspire 1,  where it literally started drifting after launch.  It was in a approved flight area.  It took me 6 months to prove to them that this was an interference problem.  I took them to task over the data report and got an independent analysis.  It helped that I've been flying for a long long time and I knew what happened the second I saw it.  I got a full refund and a personal apology
My best advice is that if you think you may have screwed up,  you probably did.   If you KNOW you didn't,  well you still may have,  but investigate it.  I could save you a lot of money.
Yeah, 24, thanks for your comments.  I was out only $239.00 plus I got a new drone but money is not the issue.  I need to know what happened AND I need to know why DJI is not responding.  I assume they are hiding something but I have no way to prove it, just with circumstantial evidence.
Thanks for your posting.
Jim
WA5TEF
2017-2-17
WA5TEF
Kirk2579 Posted at 2017-2-17 15:34
you do know this is a PUBLIC help forum NOT DJI SERVICE department
your message tells me much of you
Well, Kirk, first tell me how to recover them and I will be more than glad to share them.  First, go back and read ALL of my posts and you will see why I said that.  Even DJI can't tell me.  So, we'll see what they say then do it if they can find them.
Thanks,
Jim
WA5TEF
2017-2-17
24ctDrone
WA5TEF Posted at 2017-2-17 20:00
Jim
I doubt they are hiding anything.  This is just DJI.  They are the most innovative company in the industry by far (besides Movi, not an endorsement just well established) and they are growing so fast they can barely keep up with any type of support.  I have been waiting one month for an email back from them if that says anything.  However I have not known them to openly deceive.  One member on here awhile back put up a very well documented case of a drone being downed in a NFZ,  provided documentation,  and presented a good case as to why DJI was wrong.   Several users documented cases of Inspire 1 battery failures and in-air discharges.  As well a user very clearly and concisely pointed out and showed how magnetic interference caused the drone to improperly fly via drifting (a problem I had once too, so it caught my eye).   My point, present a clear case.
There are many things I could say about DJI analysis techs,  and I'll be fair.  The majority are great,  and I don't think want to hide anything from you (or even would think about it).   However if you can better understand your own problem and make the argument,  like I have seen here many times,  the forum will be less critical on you.   I would suggest researching your problem and looking at past circumstances for reference.  If you are 100 percent sure you had all of the props on, tightened and ready to go,  then you have every right to investigate your situation.   Get the logs and get several different opinions.  Help me out guys,  what is the group that does data analysis besides DJI (not an endorsement, a second opinion is always a good one though)??
However you already paid money,  and that was likely your biggest problem to date.  This could be seen as admitting  fault.  I've had issues in the past where resolutions have taken up to 6 months--true story,  because I knew what I saw due to experience.  For example,  I have clearances some may not,  however I have made a bone head mistake by switching controllers, and forgetting to turn off default GEO fencing.  To my surprise, it kicked in after 5 minutes in the air.  I was not able to X out of this as the rules are clearly stated by DJI.  So know the rules even if you don't agree (I made EM landing, all was well,  but not a good situation).   I personally don't agree that DJI should enforce drone laws.   That should be left to the FAA.  HOWEVER,  it is there policy,  and if you fly their drones,  you live by the letter of the law, their law.   The last thing I will say/repeat,  research, research, and research!!!! Fly safe my friend
2017-2-18
Kirk2579
Flight distance : 37415 ft
WA5TEF Posted at 2017-2-17 20:01
Thanks,
Jim
the exact process is online and depends on IOS or android.
but the process simply involves using a file manager or iTunes to go into the internal storage of the device you flew with.
If you use 2 ,and from your posts you HAVE, used more than 1 device.
check both of them.
from goggle search:
saves User Flight Records within the DJI GO App to your local mobile device (iOS/Android). These can be played back with the GO App by going to he Home Screen and selecting the upper right corner, paper plane icon, where you will find your flights. These files are stored on your mobile device -> iOS is within DJI GO/FlightRecords folder; Android is within Device Storage/DJI/dji.pilot/FlightRecord. They are normally referred to as .txt flight logs, but they are require translation into any meaningful information. Several sites will perform this translation/analysis including HealthyDrones.
there is a folder that store this data and unless deleted by the user will be there.
another google find:
http://www.phantomhelp.com/LogViewer/Upload/
2017-2-18
WA5TEF
WA5TEF Posted at 2017-2-17 19:56
Thanks,
Jim
Yeah, all of you were thinking "yeah right"!  I did not hear from 'Marquez' as he did not bother to return my call.  I called him 3 times, each time asking for a supervisor in the USA.  I was supposedly transferred to his section and all three times, I was disconnected!  I have given up on DJI.  They cannot be BELIEVED IN ANYTHING THEY SAY WHEN IT PERTAINS TO CUSTOMER SERVICE!
Should I do anything further on this, I'll report back in.
Thanks,
Jim
WA5TEF
2017-2-19
Yokota85
Flight distance : 255430 ft
WA5TEF Posted at 2017-2-1 17:49
Yeah Robert.  I luckily had walked a little ways away from the launch site and got to see it falling at an angle.  It would certainly have done some damage had it hit me!  Looks like you have some bird problems with all those on your antennas!  Do you ever use your drone to string up a wire antenna?
73
Jim
Just now caught the ham operator number when I read about the wire.
Jim
W3YE
2017-2-21
WA5TEF
Yokota85 Posted at 2017-2-21 08:55
Jim
W3YE
Yeah Jim, what do you fly?
Jim
WA5TEF
2017-2-21
fansb1fe1104
Flight distance : 3372566 ft
Kirk2579 Posted at 2017-2-15 11:02
I have read this
I have one question to the OP.
I had to send in my Phantom 4....I admitted from the start it was my fault. After syncing the records with DJI, out of curiosity I wanted to see how high I was when it crashed. So I looked at my records and the last 2 times I had flew (the time with the crash and also the outing a few days before that) Those records I couldn't find....had every other flight I have ever done, but I could not find those 2 records....No clue why.
2017-2-21
WA5TEF
tvl Posted at 2017-2-15 16:37
WEA5TEF or anyone else:
This is where I get really confused ............... just to rehash my story very briefly:
dgl, I thought I had replied to you but I cannot find it now.  In my case, DJI says there are no log files on my Phantom 4.  Also, I have no files on my devices for about six weeks to include the day of the crash.  They cannot or won't explain why.  I am still in full dispute with them about the cause of the crash which they have not and probably won't reveal!
Good luck,
Jim
WA5TEF
2017-2-22
WA5TEF
I have given up on DJI ever telling me why my Phantom 4 flipped over and crashed.  I have been in correspondence with April and last Florence, who either cannot or will not answer my questions I have submitted.  My latest data I sent in was a fairly detailed analysis of what I would consider proof that the Phantom 4 did have a problem that caused the crash.  Here is a copy of what I submitted to DJI:  This is a rather long read so most of you won't take time to read it all but if anyone sees any flaws with my reasoning, please let me know.
   I  see I will have to prove to DJI that a Phantom 4, unmodified  and in perfect flying condition did indeed flip over at some 200 feet and do a powered dive  into the ground!  That AND some 200 comments on three forums including DJI's forum proves that a Phantom 4 cannot perform such a maneuver unless some component failed.   Had even an outside force such as a bird strike or a wind gust occurred, the drone would have almost immediately righted itself according to a video I have access to.  In fact had such and event occurred,  at that altitude, it had plenty of time to right itself and had such an event happened and flipped it, it would have to had happened around four feet in elevation which would have left hardly any damage to the drone.
     Also, this video showing very clearly that a Phantom, powered and producing thrust from all four propellers will indeed recover from an inverted flight and right itself within some 4 feet of being dropped upside down.  I also have a recent video after the crash (just a few seconds) that shows the Phantom 4 laying on its top, propellers bent or broken in one piece ready for its next command and perfectly capable of flying.
     I would have expected that the damage shown on the video I made with my cellphone  along with several still photographs, would be enough to justify that the crash was as I have already described it so many times to DJI and also to the forums.
    The onboard camera somehow DENTED THE GRAY SECTION IMMEDIATELY ABOVE THE CAMERA AND MOUNT,  proved that the impact would have to have been dented with the drone inverted and crashing upside down.   No other position than inverted could have allowed the camera to make that dent.   Had I been thinking that DJI would deny my claim because they state that there is no flight log data, then I would have photographed the dent.  There is no other way that the camera could have struck the exact place on the body of the drone than by crashing upside down.  When I closely inspected the Phantom after the crash, I noticed this dent.  I then tried to see what made it and it was very clear that it was the outer rim of the camera lens holder!!!  The two matched exactly!
     Had the crash been to the side, then damage would have been to the arms holding the motors and propellers   At least two motors would have been damaged, or broken off completely.  Also, the photo evidence shows the battery still in its flying position, not like in most of the posts from the forums stating that the battery was ejected.  And since the battery was not ejected proves that the drone hit flat UPSIDE DOWN much like a stuntman would purposely land flat to prevent injury and not at an angle.
     The photos and videos showing the lights and strobes functioning properly and the battery indicating 3 green LED's and one blinking proves the drone was in flying condition except for the broken propellers and gimbal   As noted above, the camera lens ring hit the bottom of the gray area immediately above the gimbal when upright.
     Also in the cellphone video one can hear the clicking sound that the drone's radio transmitter makes.  It was still sending data.  In fact as the video record later plainly shows, the drone flying again THAT NIGHT with only 4 new propellers being added.  (That fact could also be used in advertising  proving how well a Phantom is built!)
     I do hope that the appropriate DJI employee will review the damaged Phantom 4 and check the placement of the dent, caused by the camera lens retainer ring.  By aligning this dent with the camera part one can see clearly that it was the camera lens ring and nothing else that could have made this dent AND THE DRONE HAD TO BE IN THE UPSIDE DOWN POSITION!!
​     I do hope that the person who can make a decision on this case will carefully review it.  From the reaction and action I have received since I submitted the drone for repair and analysis is not similar to DJI's policy on situations like mine where "no flight logs exist"?  From what I have learned from other Phantom owners and the forums, that is the case in a lot of the times.  I sent the drone in hoping to get it repaired AND to find out what caused the accident.  So far, I have paid $239.00 for repair and I carefully followed the "repair process" on the web site along this my serial number only to have shipped a "new" drone in its place and without any information as to why it crashed.  I believe if someone will take the evidence I have presented here and carefully review it, there could be no other decision than a warranty issue.  Clearly a Phantom will not become inverted unless something went wrong in flight and fly straight into the ground.  I have shown that if a Phantom did tip over to the inverted position, it will quickly recover and continue to fly.  I have shown that it is indeed difficult to pull a Phantom that is hovering, over to one side.  It will make a very strong effort to right itself and maintain a level flight.  I have posted this situation on three different forums and I have a large number of Phantom 4 owners who are following carefully what happens in this case.  I do hope to be able to report that my drone failed due to either software glitch, hardware glitch or design fault.  I find it hard to believe that a unit as sturdy built as my Phantom was would have a hardware fault.  I would tend to believe it more of a software glitch that suddenly caused two of the motors to shut down, or increase power for an instant, causing the Phantom to flip over and then by being inverted, it lost GPS tracking and by the same fault, could not correct its attitude.
     Please recover the drone body and camera mount and verify the dent and that the alignment of the camera ring and dent are an exact match.  Once this is done, there can be no other explanation.
     Thank you all who have read this.  I intend to post this in its entirety on the three Phantom forums if I don't hear from someone about this.  I love my Phantom 4 and will probably have a Phantom of some sorts in the future but I really don't care much for the way DGI has treated this case.  If anyone has any questions, or challenges of anything written here, please let me know.  My phone number  is 662-231-3230 and my email address is wa5tef1@gmail.com.
     Thank you for your time,
     Jim Miller
[Quoted text hidden]
Jim Miller  WA5TEF
Since I sent this to them, I recovered a video taken immediately after the crash that clearly shows the dent caused by the camera lens ring.
2017-2-27
AG0N-Gary
Flight distance : 700846 ft
Hello Jim.  This has been a fascinating thread to follow.  I just stumbled on it tonight when looking for information on how to decode my flight logs.  I still don't have that info, but thought I would let you know that my situation is similar.  After almost 2 yrs of good flights and no unexplained problems, I was about to take my new Mavic up for a maiden flight and thought it would be neat to video it from the P3A.  I fired up the P3, put it in the air and made a few basic moves to check for proper movement etc.  I put it up about 10 feet, moved it left, right, fore, and aft, and all was fine.  I then gave it a little right stick to the right and some left stick up and it rolled over upside down  and crashed down on one leg.  It was a horrible powered crash to concrete and I thought it was probably in hundreds of pieces.  The battery had popped out of it and was laying nearby, along with a couple of broken prop parts.  Two props were damaged and the top shell was split open on one leg.  It happened fast, but it clearly curled over right in front of me and was headed down when it went out of sight behind me.  Since then, when I've had time, I've been working on learning how to pull the flight log and get it analyzed.  I have the logs, but haven't figured out how to get the details.  I've been through several links and one led me here.  Yes, it would be nice to learn WHY it happened, but like you, I doubt I'll ever know.  I would just like to get access to the data to look at it myself.  This was the first actual failure of the Phantom itself since I've owned it.  I know nothing was done by me to cause it.  It was a simple sideways movement while climbing that caused it to flip over.  Not supposed to do that.  All seems well with the Phantom, but will need a new shell.  Motors all seem normal and spin freely and sound good when they are running.  I just need a shell and would love to have an explanation.
Take care Jim and would love to catch you on the air sometime.
Gary - AG0N
2017-5-27
Labroides
Flight distance : 9991457 ft
AG0N-Gary Posted at 2017-5-27 19:25
"Yes, it would be nice to learn WHY it happened, but like you, I doubt I'll ever know.  I would just like to get access to the data to look at it myself"
Go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions to upload your flight record.
Come back and post a link to the report it provides and it will probably shed some light on the incident.
2017-5-27
AG0N-Gary
Labroides Posted at 2017-5-27 20:18
Yes, I did that yesterday and it mentions something about points which I know nothing about, so didn't go further.  I do have their results, but as they say, they are not complete.
2017-5-28
12345
