JJB*
Flight distance : 12686732 ft
Hi,
Amazing flighlog, not that smart...
191x warning "Strong wind"
210x warning "Aircraft unable to return to home automatically. Lower altitude immediately and return to home manually ]"
At 6m59.6s TRH countdown, at 6377 feet away from home and at height of 1639 feet.
BUT (countdown) RTH was cancelled (why?)
Worse, continue to fly away from HP, not flying inbound to HP. (why?)
At 11882 feet away from home a long disconnect, so GoHome.
After turing towards home, at 10m24.2m, your MINI2 fight against the head wind.
Pitch down to 29 degrees, speed 14 feet/second. High batt consumption so battery % rapidly getting less.
With 23% software calculates that time needed (thus batt%) to land safely is now present, so Autolanding!
Height 1628 feet! so need lot of time to land....
Understand max foward on the controls, not the roll input.
At the end 6x disconnects....
Flying outbound with tail wind....full stick forward, speed 33 feet/sec. CHECK craft pitch = 0.3 degrees UP.
This is an easy check in flight to check the wind = not ignore the RTH as you did.
Added chart : landing postion within red circle.
cheers
JJB [ Charts by FRAP ; the 'best' software for flightlog analysis ]
