Cetacean
Flight distance : 2528264 ft
Aloha racer,
From what you are describing, disabling "Obstacle Avoidance" is your preferred option. This will not disable the obstacle sensing, so you will still get warnings, but it will not stop you.
It would be nice if DJI changed the pitch of the warnings for each direction and maybe increase the intensity upon closer proximity so you could react quicker with the sticks. And you are right, holding down the "C" button for a whole flight can be a burden. Been there, done that!
Maybe using a stick as a bar to hold it down would make it easier. But hey just disable the avoidance and let the sensor warnings drive you nuts!
Aloha and Drone On! |
