johnsr
Flight distance : 1579022 ft
The situation is the same for P3 users; mine recently went dead after a few months pause in use. I contacted the European DJI Repair Center to discover that they couldn't replace the battery either! Incidentally the Phantom flies fine with the RC controller connected to its charging supply. So I had a look inside (mine's out of warranty now) and discovered that the battery has 0.00 V at the lead ends. This is weird for a weak LiPo. The story is that there is a small balancing circuit board hidden in the end of the RC battery (probably the price of using the same charger for the flight batteries and the RC unit). I believe that it is that circuit which is dead. So I am going to try to do a DIY repair with a RX-TX battery used for other RC units. This is an inexpensive repair, but you must be aware that with a 2S1P battery you will need to balance the two cells from time to time (add an external plug to the controller).
If you're still under warranty, send it back. Otherwise, there may be an alternative...
Have fun & good flying! |
