DJI Thor
Flight distance : 13602 ft
fansf7fc0d0f Posted at 2017-6-20 14:00
Hi, I have had successful flights since with both mavics, so I went to the same place where the problem first happened and had the problem again with both mavics, I then went to my test area and had no problems. Would you still recommend sending them back? Had you seen something in the hard ware?
I've checked the flight records, it looks a bit weird. But, as you mentioned, sounds like this issue only happens in a certain place, right? If so, please export the flight data for further analysis, thank you in advance.
PS: Please export the data via DJI Assistant 2. |
