Xman1
RCNJ Posted at 2017-6-22 14:05
Hey pal I remembered you try to avoid lots of post work on vids, mind sharing your settings bud ? Having a hard time getting decent results, think you said 1080p and not above 30fps ? What color settings you use if you don't mind me asking.....
Well, I think I see your flicker issue with high detail settings. I think it is still there in the higher resolutions, but since the pixels are smaller, it doesn't jump out at you as much.
I took some video of some rocks and I can see it flicker, but I think it due to high shutter and high ISO. When I put the Polar Pro filters on, I get motion blur instead of flicker. I haven't fully tested this out yet to find the best settings to get rid of it yet though.
What I have been using lately is 30 FPS max, +1+1+0 on the sharpness / contrast / saturation settings, 100 ISO with 60 FPS shutter speed, and for white balance I let the machine decide for me and then I loc it in under custom, or I use Sunny or Cloudy default settings. Been using Cinelike for my color settings...
With that said, I have broken down and started using LUT's and the like in Postprocessing. You probably already figured that out though from my settings.
Blackmagic's Free Davinci Resolve with whatever LUT's you want to use is getting pretty easy now.
