phatav8r60
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
China
VenomousSVT Posted at 2018-1-5 12:15
i saw on amazon some bouy's that installed on the bottoms of the motors. they were basically white foam balls that slid on the bottom of the motor housings. This would likely give enough buoyancy if it hit the water not to sink completely.
There are leg extensions now that are long enough to poke into the balls, you make a hole in the ball first, then fill it with hot glue, then stick the leg extension into it. Works like a charm |
