Does Anyone hand carry inspire 1 on budget airlines
2302 17 2015-3-17
docodrone
Flight distance : 119062 ft
Singapore
Does Anyone hand carry inspire 1 board budget airlines before?
2015-3-17
pandppurchase
In the UK unfortunately Inspire in its carry case is too big size wise.
2015-3-17
colin.winglondo
Flight distance : 963560 ft
We tried to get it on board last week but was denied at security.They said the inspire itself is now not allowed airside so it has to be checked in.
Been speaking to the CAA to see if this is correct as I thought as long as there were no batteries attached to the inspire then it should be able to go through. Still it seems no one really knows what the rules are.
2015-3-17
docodrone
Singapore
Anyone travel from hong kong with inspire 1?
2015-3-17
shakyamunifilms
docodrone Posted at 2015-3-18 09:53
I just flew in from Hong Kong two weeks ago.
When I arrived at Hong Kong and went to Manila, they allowed me to carry it on.
However, when I left Hong Kong to go to America, they made me check it in. Which irritated me, because it was the exact same airliner.
But, it's understandable. I suggest investing in a Heavy Duty case. If you plan on traveling with her.
2015-3-18
Tournique80
Mexico
I bougth a Pelican case for that purpose. I hope to receive it tomorrow. I will take some pictures to share.
2015-3-18
docodrone
Singapore
shakyamunifilms Posted at 2015-3-19 02:46
When I arrived at Hong Kong and went to Manila, they ...
Hey your info is really good to me, so will be depend on your luck? The case its that fit to the budget airlines cabin??
2015-3-19
docodrone
Singapore
Tournique80 Posted at 2015-3-19 07:25
I bougth a Pelican case for that purpose. I hope to receive it tomorrow. I will take some pictures t ...
Thanks cant wait to see
2015-3-19
rodger
Flight distance : 15812070 ft
It is airline policies which vary from one to the other. Southwest in the U.S. allows it as a carry on.
2015-3-19
shakyamunifilms
docodrone Posted at 2015-3-19 17:59
Hey your info is really good to me, so will be depend on your luck? The case its that fit to the b ...
Glad to hear that!!
Basically, if you get past the guards before x rays begin, you're through. Im guessing, everyone after that just assumes it was approved.
But I suggest you get a heavier duty case, just because they WILL make you check it in if they see it.
I feel like I got pretty lucky. But who knows, you can test your luck!! haha it's not impossible that's for sure. If you do try and sneak it, just try and avoid being alone so they don't scan what your carrying. Try and keep the case discrete. I'm thinking the busier, the better. When I was stopped, there weren't very many people in line.
And just for your info, I flew Cathay Pacific Hong Kong to LA.
2015-3-19
Tournique80
Mexico
I just received the case yesterday. As you can see, no modification is needed, the original DJI case fits perfectly inside the Pelican case.
2015-3-20
docodrone
Singapore
Tournique80 Posted at 2015-3-21 07:27
I just received the case yesterday. As you can see, no modification is needed, the original DJI case ...
Congrats tournique80 , you bought without foam?
2015-3-22
kelleyre
Flight distance : 59199 ft
did you have to remove the handle or the pegs on the edge
2015-3-23
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
Where can i buy this case online? Was looking for a solution but didn't want to pay 500usd, excellent choice...
2015-3-23
Tournique80
Mexico
I bought with foam, but finally it was not necessary. It cost me 230 dollars at BHPhotovideo.com. It is not necessary to to remove anything of the DJI case.
2015-3-26
leoamartinez
Dominican Republic
I flew from SDQ to Miami, and had no problem hand carying the Inspire in its stock case, but when i was returninf from Miami to SDQ the TSA didnt let me go through, not a problem eith the drone but with the size of the case, was very worried cheking in the bird. Then it ocurred to me that i could turn on my trackimo device that i use with the drone, that way ill know where my bag will be at all times, anyways, ill be buying a case soon!
2015-3-28
powerhs
Flight distance : 1195696 ft
Tournique80 Posted at 2015-3-27 13:10
I bought with foam, but finally it was not necessary. It cost me 230 dollars at BHPhotovideo.com. It ...
wich case is it mrl. #
2015-3-28
freebygsy
Rememeber you may not be allowed to check in lithium battieres on all airlines, most request you put in hand baggage,
enample guide
http://www.virginaustralia.com/au/en/plan/baggage/batteries/
2015-5-20
