Signing in to Assistant 2
12
29222 61 2017-7-1
fansa23e161d
Cannot login to Assistant 2. OS-w7 pro; security SW Norton 360; even I can see the captcha and fill in the verification code -> network error 1-6. Incompatible app from MS.
2017-11-23
djiuser_iNpOQnC
same problem
2017-11-28
fansbfe17ad2
Flight distance : 49626 ft
Just reading through all solutions for this issue and I cant see verification code.
2017-12-17
Rancher
Flight distance : 56824 ft
Yea, I just install the Assistant and the captcha is blank so will not allow me to log in.
Googled everything out there and nothing.
2017-12-17
allen_fletcha
Yes just got a DJI OSMO Mobile and trying to sign up with the App and verification Code is blank. Also When I create an account online it does not allow me to login in the app either.
2017-12-25
Dbuxy
Flight distance : 344547 ft
I have this problem too, anyone find a fix? I followed all previous suggestions
2018-1-20
stevelarsc
India
This verification code is a captcha picture which appears on the login page itself. I am not sure why it is not displaying in your login screenshot. This might be due to some browser issues. You can visit  http://www.howtofixbrowserissues.com/ where you get tips on how to fix browser issues like this, Thanks
2018-2-21
djiuser_bgPHqFVacCA3
stevelarsc Posted at 2018-2-21 01:09
I had this same problem.  My solution was found here.
https://learn.sparkfun.com/tutor ... cement-on-windows-8
The short:
You need to remove the application, then temporarily disable driver signing, then reinstall the application as administrator, then reboot your computer.
Also make sure all text fields have information in them.
Hope this helps.
2018-2-21
djiuser_lifukranURwR
Same problem here, no captcha visible. Come on DJI get this fixed!
2018-2-27
djiuser_2MvPubWcx8Uo
Switzerland
I had the same problem here. On a Mac.
First of all: It can't be a «browser problem», because the assistant IS the browser. I never had problems registering or logging in on dji.com. The problem only exists in the newest DJI Assistant 2 v1.2.0.
– First install
– Activated the blocked system extension (can't remember the name, because the alert doesn't appear anymore)
Sometimes there was simply no captcha-code, sometimes there was a broken-picture-picture.
Here's the key: I use Little Snitch. Newest version. Silent mode (allow all connections). After deactivating Little Snitch everything worked fine.
Maybe this helps.
2018-3-25
QuadKid
Flight distance : 482349 ft
Drone.Nomad Posted at 2017-7-2 09:58
Yep that pretty much sums it up :-)
The latest Version of Assistant 2 is version 1.2.3, I would try update Assistant on your PC/Mac and see if the problem persists
2018-3-25
fans589b29e7
QuadKid Posted at 2018-3-25 02:45
[view_image]
Had the same problem: Windows10, Assistant 2 ver1.2.3, no verifation code displayed.
Solution (for me, as already mentioned above):
Run "Assistant 2" as administrator  (right mouse click) -> verifation code is displayed - login works fine.
2018-4-23
Brutale
Flight distance : 26 ft
I just clicked on the BOX where the Verification Code goes and the code appeared to the right.
2018-4-26
sky_makai
Flight distance : 3397539 ft
I got it to work by clicking in the area where the Captcha is supposed to be.  After two or three clicks, the Captcha appeared.
2018-7-9
DJI Tony
sky_makai Posted at 2018-7-9 16:41
That's great to know, kindly inform us if you need our assistance.
2018-7-10
Binu luwangcha
Flight distance : 138340 ft
India
verification code is not appear
2018-10-21
Wanbli
Flight distance : 3848497 ft
DJI SOFTWARE SUCKS!!!
2019-8-6
Not A Speck Of Cereal
Flight distance : 666493 ft
2 years later and this is still happening.
Latest Assistant version, Win 10, uninstalled, reinstalled, Run as Admin, whitelisted in malware blocker, clicking all over the frickin' place and VERY FRUSTRATED.
Flight tomorrow morning, DJI Go Telling me to calibrate the visioning system, so I assume the M2P obstacle avoidance sensors are compromised until the calibration occurs.
BUT I CAN'T BECAUSE THE VERIFICATION CODE DOES NOT APPEAR!
"Did you try using another computer?" IS NOT A PROPER RESOLUTION. You shouldn't even ask a user to do that. The software should install on any valid PC with the proper / supported OS.
PERIOD.
2020-10-31
djiuser_biDe5iDv3Vpf
Make sure you are NOT on a VPN.  It won't generate a verification code if you are.
2021-8-17
Scatterblak
Dead wrong here. For many people, it doesn't appear.
2022-7-3
djiuser_8dK91AGwLYwQ
Drone.Nomad Posted at 2017-7-1 12:44
Thank you for your reply, as you can see on mine this does not appear??  I will uninstall it and try again.
SOLVED
For PC- Right click on DJI Assistant Icon select properties-Compatibility, change compatibility to Windows 8 and select Run this program as an Administrator. Boom problem solved. The captcha will show.
2022-11-23
JI_Snow
I clicked around until I hit a button that brings up a new code and then it showed up.
2023-2-21
12
