mattd
Hi guys, there is a guy over on RCgroups who has both the cinimizers and fatshark HD. Here is his view on them
Surrogatemarker writes:
For a "Inspire only" set of Goggles.. Then at the moment I would choose the Cineimizers, if you plan to fly other multirotors or FPV planes in addition to the Inspire , then the Dominator HD's win..
Cinemizer pluses:
Lighter and more comfortable but also get the eye shields or cups as they come separately to better block light leaking in around the sides of your eyes. Slightly clearer picture than the Dominators but that may be just be me.. It's not a big difference and others see no difference.
If you plan to use the OSD you will see more of it on the Cinemizers which have a wider rectangular screen effect than the Dom's which present a more square screen effect. Although squarish.. The screen seems closer and slightly bigger with the Dom's .
Dominator HD advantages: separate batteries so you can buy and charge more than one for a full day of flying. The Cinemizers have a single cable attached battery and control pod that you can't remove and it's also where you plug in the HDMI video source.
If you install a nose cam on the inspire as a pilot camera, the Dominator HD, or other SD goggles will be needed as you will likely be using 5.8 ghz video transmitter with SD video and the Dom HDs can display both 720p and. SD 480p video sources.. So can the Cinemizers, but they have to use a cable to a ground station setup as they have no wireless video reception capability.. With the Dominators, you install a receiver module and 5.8 skew planar antennae on the left side of the goggles and you are in business with no wires.. This is also the case if you plan to fly other quads like racing mini quads or even FPV planes.. The Dominators win if you are going to fly multiple aircraft both HD or SD FPV..
Bottom line.. If you want the best Inspire only goggles.. The Zeiss Cinimizers win in my opinion.. But before you separate yourself from roughly $700- 800 bucks.. Do a last thorough scan of all soon to be released goggles.. There will be many more google options on the market this summer and later this year...tech moves so fast, the best goggles right now, may be "soooo last month" very quickly.
Either way.. I suggest if they are in stock at B&H photo, get them there.. As they have a no questions asked return policy.. Buy the Cinemizers, and if you love them, don't look back, if you don't.. return them and get the Dominator HDs.. Best Regards, Mark Williams
