Mirek6
Flight distance : 609724 ft
AlexNo,
If I were you, I would escalate the claim with DJI again. Perhaps one of this forums DJI moderators can help you?
Perhaps there were some newbie pilot mistakes you made, as I pointed out in my post #547.
However, your Spark had problems from 15 seconds after start. Its altitude data was getting confused and it was getting out of whack as you flew over the ground. This should not have happened and does point to Spark’s malfunction (or perhaps your VPS sensor was covered with dust?)
Normal behaviour is that to about 8 meters altitude, when flying up, both barometric and VPS sensors are in sync. Higher than about 8 metres VPS normally shuts off and barometric takes over.
Its not what was happening with your Spark. At altitude of 20 metres above the ground, VPS shows 5 metres altitude.
When you lower Spark and fly over the pond, this out of whack arrangement holds. At some point barometric sensor shows 28 metres below where you started. This, looking at the picture, is false reading.
At this time I believe you were flying on VPS sensor but with VPS sensor messed up from the very start.
DJI may say that VPS was fooled by the water and thought it was higher while it was very close to the water. But VPS sensor showed erroneous measurements from the very start when you were flying above the ground.
DJI’s conclusion is flat wrong. Yes – you hit something (water) but not at -22 metres but perhaps (again – looking at the picture since altitude data you have in logs in unreliable) at -3 to -5 metres.
They did not do their analysis correctly, but, I have seen it time and again, that with this forum moderators help, you can get the case reopened and re-analyzed.
The loss of signal is unfortunate, but could be contributed to anything, perhaps you mobile, perhaps Spark. I do not see any obvious interferences around (lamp posts which I see on the picture should not interfere too much and you did not get interference warnings in logs).
Perhaps DJI can recover your stick movements from some other logs using methods only they know. I can’t see them.
Contact DJI again and be firm. Their support, in my experience, is quite good but sometimes you need to give it an extra push. Good luck!
