ESC status error after latest update
123
28123 93 2017-7-7
Lavolp
Flight distance : 69442 ft
Brazil
Tá fodido amigo. Nem a DJI sabe arrumar este defeito.
2020-2-18
zvo
Mexico
hey Susan I have the ESC Error issue phantom 3 advanced, please send me the file
thanks
2020-3-25
mpoquet4
Argentina
FrankNnaji Posted at 2018-2-14 04:33
Hello guys I recently cleared my ESC error after months of trying so many solutions.
My case: ESC error with loud constant beeping and no LED lights were on at all (ever, not even on start up).
I knew it was a firmware error so a reload of the firmware (1.10.09) was needed but over 10 attempts failed. Tried to downgrade to previous FW the normal way but that failed. FINALLY found a method that allowed me to downgrade to previous FW versions as far as original FW. (My issue was resolved on first downgrade attempt to FW V01.09.06)
Hello my name is Matias Poquet Villalon, sorry for my English, and I am from Argentina, I tell you that I have a 3av phantom and I have the same problem as you, I get an error message with the ESC and the engines do not start. I know you could solve it, please explain how? From already thank you very much. Greetings.
2020-4-21
djiuser_ltkbjsp5m9Tk
HI I have ESC status error issue on Phantom 3 Advance. I have tried to refresh firmware with  1.11.30  but still have the same problem. Drone was never crashed. any help would be really appreciated. Thanks
2020-5-2
LuukR
I have the same error on the DJI Phantom 3 Adv. Firmware is listed as 1.11.20+ but the motors wont start and it gives me an ESC error.
How can i fix this?
2020-6-3
Yokayzn
South Africa
Hi Susan
I have the ESC Error issue on my phantom 3 pro, please send me the file that fixes the problem......thanks in advance.
regards
2020-11-21
Naiza3k
Flight distance : 11125 ft
Can I please get the link for the firmware as well? Pulled out my P3P for my kids to play with , updated the firmware and same RSC status error now.
2-8 16:19
DanielJacksun
DJI Susan Posted at 2019-8-4 01:19
Of course. I've sent you a message in PM, please kindly check later.
Susan, I am am experiencing the ESC status error and thought you might be able to provide guidance.  The error appeared suddenly after months of normal operation.  I updated the firmware on my Phantom 3 Advanced drone, but that did not correct the problem--I am still getting the error.  Is there a possible fix for this that you can share?
2-13 17:29
DJI Susan
DanielJacksun Posted at 2-13 17:29
Hi, I had sent you the link to the beta firmware. You may try to update the beta firmware and see if the error persists.
If yes, you may need to send the drone to us for further diagnosis.
2-14 01:53
DJI Susan
Naiza3k Posted at 2-8 16:19
Sorry for the late reply, I had sent you the link to the beta firmware.
2-14 01:54
DJI Susan
Yokayzn Posted at 2020-11-21 20:26
Hi Susan
Hi, I am sorry for the delay, I had sent you the link to the beta firmware, please check.
2-14 02:56
DanielJacksun
DJI Susan Posted at 2-14 01:53
I received the link, but the name of the downloaded file starts with P3S rather than P3A.  My drone is a Phantom 3 Advanced.  Should I try this firmware?
2-15 10:54
DJI Susan
DanielJacksun Posted at 2-15 10:54
The firmware is correct, no worries.
2-21 00:16
xVladX
Thailand
Hello,
Can I have the 1.11.30 firmware?
I have the same problem, Phantom 3 Pro, ESC status error after a flight, no crashes
2-24 01:37
123
