Aircraft totally unstable and aggressive after recent firmware up...
wangrincreation
Flight distance : 984436 ft
Jgrimmy Posted at 2017-7-23 16:06
Is there a method to downgrade the controller?  Its not recognizing the downgrade version and I think may have something to do with my front collision avoidance cameras not being recognized.
Try downgrading to 1.6.0 with DJI Go app
2017-7-23
Duchunter
Mugre Posted at 2017-7-23 16:49
It is a Windows problem. Restart the PC by pressing the Shift key, a restart option will appear, option 7 (boot without drivers) you give Ok and then launch the Assistant and recognize your P4
Assistant sees my p4 but it doesnt see my controller and now my wifes pc is updating so I cant do a damn till its done. WHY NOW!
2017-7-23
wangrincreation
Duchunter Posted at 2017-7-23 16:42
DJI assistant 2 doesnt recognize either one of my controllers. Clearly im doing something wrong. How do you hook the controller to the pc for update?
You have to press for few seconds on DJI Go App horizontal bars to access the menu.
2017-7-23
Punchbuggy
Flight distance : 483166 ft
Hi. Right actions but wrong reason. The Assistant 2 installation incorporates an unsigned driver - why this still isn't fixed, is anyone's guess. Windows by default will refuse to install an unsigned driver, so you need to install it with driver signature enforcement turned off. Process is in last post here: http://forum.dji.com/forum.php?m ... D407%26typeid%3D407
So, no - it's not a windows problem. It's DJI wrapping a Vision USB driver into their installation which doesn't pass a reasonable Windows safety check.
2017-7-23
Trump
Flight distance : 139295 ft
wangrincreation Posted at 2017-7-23 16:54
RC 1.8.0 never been good. Before updating my P4 with the buggy firmware, I stayed on RC 1.6.0.
Thats what I have
2017-7-23
Jgrimmy
Flight distance : 90653 ft
Finally figured out downgrading RC to 1.6.0, rest P4 to factory, reinstalled downgraded firmware, deleted and reinstall GO4.  Still no collision avoidance.  any other ideas?  Not the end of the world but it would be nice if it was working.
By the way I cannot say thank you enough to everyone helping out here, a really great group.
2017-7-23
fans0e00ebfc
Flight distance : 477851 ft
I couldn't downgrade to 1.8.0 the system will tell me I'm on 1.9.2 (latest) restarted and same last version...
2017-7-23
Duchunter
Maybe im hooking it up wrong. I do just go from the mico usb on the controller to the usb on the pc correct?
2017-7-23
Goof
Flight distance : 666483 ft
Duchunter Posted at 2017-7-23 08:35
You better do it fast because DJI is having all these previous firmware versions removed all over the internet. They do not want you downgrading under any circumstances.
They can't do squat. Their very flight software that runs the Phantom is in severe violation of the GPL as it is, they need to sort that out before they can try claiming IP rights on firmware files.....
2017-7-23
Mugre
Flight distance : 54058 ft
Argentina
Punchbuggy Posted at 2017-7-23 17:10
Hi. Right actions but wrong reason. The Assistant 2 installation incorporates an unsigned driver - why this still isn't fixed, is anyone's guess. Windows by default will refuse to install an unsigned driver, so you need to install it with driver signature enforcement turned off. Process is in last post here: http://forum.dji.com/forum.php?mod=viewthread&tid=104088&extra=page%3D1%26filter%3Dtypeid%26typeid%3D407%26typeid%3D407
Ok. You are right, it is not WIN10 problem, the problem is the unsigned USB driver, I express wrong.
I got the connection as indicated above, not ideal, but I got the connection.
2017-7-23
Duchunter
I shut off the driver signing buts still not showing up. It shows up in my connected devises but assistant 2 isnt seeing it.
2017-7-23
G1DTF
Flight distance : 230151 ft
Jgrimmy Posted at 2017-7-23 17:19
Have you tried re-flashing back to the latest buggy firmware to see if your collision avoidance returns.
You can then roll back again to see if it still doesn't work with the older firmware. I have not yet upgraded my P4 to the new version due to all the negative feedback but if I get chance tomorrow I will run the DUMldore software to make a backup of my firmware and compare it to the file I downloaded off here.
2017-7-23
fansd9f9bc09
My craft is doing the same problem but shakes in hovering and brakes very weird.
2017-7-23
Duchunter
Roll back with itunes:
2017-7-23
Duchunter
G1DTF Posted at 2017-7-23 17:48
See if you can make a backup of your controller. I think that may solve the issue
2017-7-23
Maxnew
Flight distance : 835016 ft
Brazil
Icer Posted at 2017-7-23 14:01
Thank you very much!
I will flash it on my drone, test it and give feedback.
Please cud you check one more thing: then you connect you drone to assistant2 (last version) and start calibrate VPS cameras, - calibrate is success? (do you see that small cameras working?)
Hi, Icer. After the downgrade your VPS is OK?
Are there warnings?
I've experienced erros in my P4 2 months later.
Sent the drone to the reseller to solve the problem.
2017-7-23
Jgrimmy
No I haven't. Great idea I'll try it tonight. Would love to have a copy of what you back up off your P4.
2017-7-23
fansa920bc60
My drone just dropped off like wood after todays upgrade! too dangerous to fly!!
2017-7-23
Gablopez
Flight distance : 515679 ft
fansa920bc60 Posted at 2017-7-23 18:54
Mine too, it falls like a rock when descending. It's really scary
2017-7-23
Jgrimmy
Jgrimmy Posted at 2017-7-23 18:43
Reinstalled latest buggy firmware and collision avoidance was back.  Reflashed with V02.00.016 and it's gone again.  really weird.
2017-7-23
Icer
Flight distance : 431079 ft
Latvia
Duchunter Posted at 2017-7-23 15:16
I tried to backup the rc firmware as well but the app didnt see it. It could be that ive never used assistant to update my controller. I did use assistant 2 to update my old MC so the drivers were definitly installed for that. If anybody needs it ill see if I can make it work.
Hi,
This utility not have possibility to read flash from P4 RC. It works only with mavic RC.
But you always can downgrade RC controller with GO4 by holding right up corner button for some time.
Do not try get flash from your P4 RC.
2017-7-23
Icer
Latvia
Maxnew Posted at 2017-7-23 18:30
Are there warnings?
Hi,
Like other peoples says, VPS cameras not working, but all other functions is back and works well.
If I need to choice flight with my P4 without VPS or see how expensive coffee table I have with VPS, then I chose first option. I am sure that VPS will be also fixed very soon.
Anyway, you have always option to go back to last buggy firmware 02.00.0106 by using your backup or asisstant2 and VPS will works again.
2017-7-23
Punchbuggy
Hi team. I'm curious - has Anyone been provided access to the P4 Beta offered by Natalia starting 3 days ago yet?
2017-7-23
beeper
Icer Posted at 2017-7-23 12:02
Hi,
Yes! exactly! Please, make your firmware backup by using tool that i link before (https://mega.nz/#!nJcAUICR!3OWhm3sX34zBXPwM9T64cGImzpovIqo_6In3VnHXu5M).
Download tool and extract it in some folder. Then connect your P4 to PC. Start file "DUMLdore.exe" . Then select "aircraft" and press button "backup firmware". Backup is very fast 1-2 min.
Hi Icer
I have a copy of firmware V01.02.0503 using the tool as a backup. This firmware enables the use of head tracking with the Avegant Glyphs.
2017-7-23
G1DTF
Jgrimmy Posted at 2017-7-23 19:27
If I get chance in a bit I will backup my current craft firmware and post a link on here for you.
2017-7-23
Irate Retro
Can I ask a dumb question?  (From a software engineer.)  How can downgrading to your previous firmware disable the VPS?  I mean by downgrading the firmware you should have restored the aircraft to its previous state more or less.  It should have no way of knowing that the VPS "should be" disabled, even if it wanted to do so intentionally.  There must be other data files in the internal memory which are causing this.
2017-7-23
Icer
Latvia
beeper Posted at 2017-7-23 23:41
Hi Icer
Hi,
Please cud you put this firmware to download?
2017-7-23
SomeoneElsesDro
Flight distance : 419669 ft
Punchbuggy Posted at 2017-7-23 23:38
Nothing yet PB. I (and many others) were told it should be waiting for us in Assistant 2, but nada.
Just as a side note to those taking matters into their own hands and flashing their birds to roll back to previous firmware - I appreciate your reasons for doing so. I am reading your posts with interest and I think you've successfully highlighted the reason that DJI needs to act quickly. If this carries on I may have no choice but to follow suit. But do you think maybe you could start a separate thread for this process?
At the moment, this thread contains the closest thing we have to a response from DJI and as a lot of people here aren't comfortable with the notion of an unapproved process, it would be good if we could keep the channel clear for a direct fix from the powers that be.
Cheers,
SED
2017-7-24
user1b6725ade7
Romania
Hello I have a problem with a Dji p4.I tried to up grade the lățește firmware and în progresa I lost the internet connection and battery drain ouț. Sincer then the drone sensors are not active!what can I do?
2017-7-24
Pareja IV
Flight distance : 1084961 ft
No, no new firmware in my account whet I open Assistant 2. Stii waiting
2017-7-24
Zisojohn
Greece
Dji Natalia, why does not anyone J U S T  I N F O R M us what to expect from you and when???
2017-7-24
fans27dc0c8d
Flight distance : 1461611 ft
Hi Icer
Can you please upload it and send me the link cheers
2017-7-24
Icer
Latvia
fans27dc0c8d Posted at 2017-7-24 02:27
Hi, I have not this firmware. Beeper has it and I also ask him to upload and give link.
2017-7-24
SomeoneElsesDro
DJI Natalia Posted at 2017-7-21 03:58
Thank you, I have forwarded the info you provided to engineers, please feel free to let me know for any further questions.
Natalia, can we get an update as soon as possible please. Your last message implied we should have the beta firmware by now?
2017-7-24
StrelokL2
Flight distance : 334311 ft
Russia
i think DJI plaing for time
2017-7-24
Irate Retro
I cannot believe you guys fell for the ol' beta test list routine.  P.T. Barnum was right; there really is one born every minute.
2017-7-24
beeper
Icer Posted at 2017-7-24 02:35
Hi Icer
Link to firmware V01.02.0503
https://mega.nz/#!RnJEDSCY!b6Pl8 ... QPOAR4KGletwq2sX7sQ
2017-7-24
Icer
Latvia
beeper Posted at 2017-7-24 03:14
Hi Icer
Link to Firmware V01.02.0503
https://mega.nz/#!RnJEDSCY!b6Pl8gDd9RhRRuBmYNsqfWlbQPOAR4KGletwq2sX7sQ
Hi Beeper,
2017-7-24
Duchunter
beeper Posted at 2017-7-24 03:18
Hi Icer
Thank you Beeper. Im beginning to wonder if my firmware that I uploaded wasnt corrupt in some way. If its a backup straight from my p4 then everything should work. Everything said it went fine but there shouldnt be any sensor issues. Hopefully the gang can get yours working.
2017-7-24
fans27dc0c8d
Hi Icer
thanks, am i correct in saying this can be loaded with the backup/restore tool.
2017-7-24
