Icer
Flight distance : 431079 ft
Latvia
Hi all,
Just finished all tests with firmware.
Lot of things and application links already posted here, by this reason i not give some links but just tell very important features...
Yes, downgrade DJI firmware is possible and not only for P4 but also for lot other aircraft models by using same utility.
Before make any actions with your drone, you must make original firmware backup.
To downgrade to v602, you don't need v503. Just make flash 2 times. First time all files get to be replaced according "master cfg file", second time completely all files get flashed.
If you have second battery, you need make flash Nr.3 with same firmware.
Always see on led indicator. On the end of upgrade/downgrade, led indicator get green. During flashing it can be orange or red/green flashing.
Second time then flashing same firmware, this take much less time.
Then battery get flashing you can see two middle lights flashing.
Firmware file must be in the root directory of utility and called dji_system.bin
To be sure that you has successfully flash new firmware, you need look status in the GO4, if firmware is not appear you must re flash.
After first flash your battery turning off very long time and VPS not active and can not be calibrated. After second flash, battery turning off fast and VPS can be calibrated.
To do any actions, you must wait till drone warm up and status lights fast blinking orange.
RC controller must be always off.
RC controller last version 1.9 is ok and works nice
Utility works only on WIN OS systems (tested on WIN 7).
If you still have problems with VPS calibrating (message - restart your drone), try disconnect internet and try again (but only after 2 same firmware flash)
Of course (i think) you loose you DJI warranty by do firmware upgrade by not official way.
Factory firmware can be restored by assistant or making flash back your stock firmware from backup.
Hope that lot of peoples will get lot of positive moments by flying DJI products now after fw downgrade. DJI make perfect drones! They flight like a dream. But they support are awful. DJI please cud you stop give some empty promises and asking "stupid" questions - have you balanced propellers act...
Seen one video on youtube with one man who loose his P4 in swamp because of broken propeller. I measure temperature of my P4 motors after flight with v02.00.0106 and terrible shaking - i was surprised.
Think that propellers just melt (but it is only my opinion and observations).
Thanks. |
