Nigel_
Flight distance : 388642 ft
Assuming that RTH is set to a legal 400 ft and you are flying at 1600 ft when it looses signal, it will return to home all the way at 1600 ft.
If you have dropped down behind your wood then it will head for the trees, not good so you need to set RTH to the height of the trees relative to home + a little extra.
The other problem is that RTH obstacle avoidance will not climb over the trees if that requires going higher than the maximum height you have set (500m?) and the aircraft will then get stuck and eventually land when the battery runs out - set the maximum height high enough to be able to return over any obstacle, or don't go behind anything higher than maximum height.
Obviously when/if it gets back into radio range you are going to have to take control back and fly back keeping it within the 400ft above ground limit, not let RTH fly back at 1600ft above the ground. (you don't need to exit RTH for that.)
Make sure you keep it sufficiently in sight for you to be able to avoid any unexpected helicopters. |
