Mike9129
Flight distance : 4112812 ft
id a similar problem,
if the connecter on the back of where you plug in the gimbal (the first image that dji mindy posted) is loose youll have image transmission problems. plug it out, maybe give it a blow of air to make sure its not dusty and plug it back in.
if that doesn't work, check your connectors inside the nose of the aircraft. plugging them out, blowing on them and plugging them back in has solved this problem for me before.
to remove the nose cone, theres the 4 obvious screws on the outside connecting it to the rest of the aircraft, plus 2 more tiny screws that come up from the bottom, right above where you plug in the gimbal (right above where those wires in image 1 are). you need to unmounts the front of the vibration plate to have enough room to get at them really. once the 2 screws are off, the nose will slide straight forwards and youll see a few more connectors in there. unplug and replug them in.
that's solved the issue for me at least. |
