Fastest way to charge Spark via USB?
12
24610 56 2017-7-10
Dirk52
Flight distance : 232995 ft
fans9ea9c44f Posted at 2017-8-27 10:30
Well if the dji charger charges in 30 min then it must charge at 2C. And it must be supported.
The spark battery can be charged with <3A.
Over 3A the battery will stop the charging process.
2017-8-27
ImHereToCrash
Flight distance : 5381368 ft
Dirk52 Posted at 2017-8-27 10:42
i have read it can use 5V and 9V chargers..  and 2.45Amps on 5V and 1.66amps on 9V   but i dont know since none of my quick chargers i owned worked with my spark, when i had it, in quick charge mode, just standard 5V mode.
2017-8-27
fans9ea9c44f
Flight distance : 22129 ft
Well 3 amps is 2C.
2017-8-27
R&L Aerial
Flight distance : 298100 ft
CoreyB10 Posted at 2017-7-10 22:20
Lipo batteries and MAH charging rates. DO NOT CHARGE THE BATTERY OVER THE MAH OF THE BATTERY. So, in human terms - The battery for the Spark is 1480 mAh. The general rule of thumb is to put a point after the 1st number. This would mean that a charging rate of 1.4 amps for the battery. You could get away with a 1.5 amp charge as most decent 3rd party chargers have an amp setting which you can set to the capacity of the battery. Charging any Lipo battery over the simple calculation could result in this happening -
https://www.youtube.com/watch?v=5U3h_46ZKcQ
i really don't think that too many people hook there cellphones up to the good old jumper cables?
2017-8-27
XNOHAT
Flight distance : 1611 ft
Vietnam
Can I charge my Spark with just a powerbank ?
2017-8-27
Dirk52
ImHereToCrash Posted at 2017-8-27 10:49
The charger included in the fly less package is a QC3.0 charger.
It charges the Spark with 12V and 1.5A. (18W)
2017-8-27
ImHereToCrash
Dirk52 Posted at 2017-8-27 12:19
must be a protocol not engaging for most standard quick chargers..maybe some handshake failing because dji limited it..... when i had my spark it never worked for me..  could just be my fault but i also  have an anker quick charge 3 battery bank and that acted the same, sluggish, good if nothing else.. hmm..
2017-8-27
fansf08b17e5
So how does that DJI charger charge it faster, the battery must take higher wattage that 18w unless is the micro usb that is limited.
2018-1-5
heliman
Denmark
Dirk52 Posted at 2017-7-11 04:12
I don't own one of these powerbanks, but what I can say is that a QucikCharge 3.0 compatible one is the fastest way to charge the spark via it's usb port.
It will take about 70min (10% to 100%) with a 12V/1.5A charger.
Remember that the 30.000 mAh is for the internal power bank battery, which is 3.7V,
30.000mAh@3.7V = 111Wh.
Enough for 6 charges - not 9.
2018-1-5
Zbig
Flight distance : 7349 ft
Poland
fansf08b17e5 Posted at 2018-1-5 06:34
Not sure I understand your question. Spark will draw a maximum of 2A from a generic 5V USB supply for a total power of 10W and 1.5A maximum at 12V from a QC power supply for a total power of 18W.
In any case, the Spark battery is not connected to USB charger directly, very far from it. First off, the voltage has to be boosted up to over 13V needed by the 3S battery. The actual charging process it tightly controlled by the circuitry inside the battery case; it's way outside the USB power supply's competence. See my more detailed write-up where I try to clear some confusion regarding USB charging.
2018-1-5
JohnRaggio
Flight distance : 30794 ft
Interesting.  Thought the charger read 3amp.  Is It ok to use 2 amp ipad charger?
2018-1-28
Dirk52
JohnRaggio Posted at 2018-1-28 09:57
Sure, you can use a 2A iPad charger. But it will be slower.. 2A @ 5V is only 10W.
2018-1-29
fans2bf9ae52
Would it be okay to use a power inverter with the normal charger
2019-5-28
Tentoes
Flight distance : 6018255 ft
OneMatt Posted at 2017-7-10 07:14
Does this mean I can use any QuickCharge 3 compatible charger for the Spark? It would be nice to have a decent car charger....
Yes. It charges nicely from my cellphone's "turbo" charger in the car.
Hard to find things on the DJI site. Instead, use google http://lmgtfy.com/?q=dji+spark+3+battery+charger to get: https://store.dji.com/product/spark-battery-charging-hub
2019-5-28
Eddie1215
I finally got my third battery and do not use a multi-charger. I have realized that once I burn them up it is time to go inside and wait for a little bit. Love my spark!!!
2019-5-28
fans2bf9ae52
Instead of using your power bank why can’t you use a inverter and using original charger
2019-5-28
fans2bf9ae52
2019-5-28
12
