Gerry1124
I think it is. More instructions on page 2.
Well F me.... Mine is spinning on a dime now.... I lucked out and stuck the right about of papers under to balance her... She spins on her axis on a dime now.
For anyone else having issues, you need to find out which way its drifting... You need to raise the opposite side of the drift with a few pieces of paper. Re-calibrate and test your flight. If it still drift to the same side, re-calibrate it and raise the opposite side more. If it drifts too much to the other side, then remove a piece of paper.. The MOST IMPORTANT THING IS TO ALWAYS PLACE YOUR CRAFT IN THE SAME EXACT SPOT, AND FACING THE SAME DIRECTION WHEN DOING THE IMU... Manipulate the level with peices of paper...
These IMU's need to be dead center to the millimeter.
Hopefully it helps the many people out there who had my issue. Mark this one solved. |
