Dean.w
If you're having trouble changing to or from 2.4ghz/5ghz - where hitting apply has no effect, I have the solution.
Change the wifi to the frequency you want and THEN modify the NAME of the wifi, THEN hit apply. You'll lose your connection to the Spark and a new network with your chosen name and frequency will appear.
Not sure why you have to do it this way but it's the easiest way i've found to do it.
