OneMatt
Flight distance : 155984 ft
The orientation of your antennas matters. This is in the manual. If you do a rocket, and the RC antennas are vertical to the ground (antennas pointing at the Spark above you), you are in the antenna dead zone, where the reception is weakest. Angle your antennas flat (horizontal to the ground) and signal should stay. |
