hallmark007
Flight distance : 9827923 ft
If you loose gps your aircraft doesn't know where it is so cannot RTH , it will go into Atti mode, if it does best to raise AC higher to try pick up gps, other than that if you can fly it home or land in a safe place, atti can be tricky at first don't panic your AC will move on the wind it won't loose height, you will need to be positive with stick inputs, also use map triangle to get heading. If you manage it once then you should be fine. It won't happen often hopefully never. |
