ImHereToCrash
Flight distance : 5381368 ft
this isnt designed to scare aware potential new spark users, but i am posting this for a realistic view and review of sorts.
if you are on the fence about buying a spark, i reccomend holding out a while longer. i cant say how much longer, i dont think DJI will be ignoring the spark users here. so hopefully within a month or so...
things i noticed since joining this community and since flying my lil sparky(for the short life it has lived, RIP).. the DJI spark is drowning in issues, yes, there are people that seem to have better luck and gotten a golden example of a Spark, im happy for them however, dont count on your spark being a golden eaxample..
there is alot of repeat issues, including but not limited to:
Spark randomly having power cut off by the battery and falling at random, usually ending its short life. this is less common, but it seems to be increasingly common issue, becareful.
the spark almost has a fetish for disconnecting and disobeying the user commands, this includes my case which is with a controller and OTG cable, it just decides it has better things to do like climbing trees and running into things at full speed even if last command you gave it was to do nothing, and ignroing pause button or RTH button is another problem...mostly related to connection issues
flyaways, basically drone decides it wants to go sight seeing without you reguardless what you hve to say about this, usually ends well if you can reload the connection/link, but if you cant and its gone sight seeing without you, it can fly into unknown forever....be very careful.
return to home getting reset during connection and channel hopping, haappened to me a few times.. i was getting daring wiht my drone, took it out over quarter mile it reconnected and decided new home location was where it current was, which lcukily you can change in app to where you are standing, doesnt mean it will obey you. however im not sure how often it happens to others, i seen it a few other threads, i experianced it, nothing cant correct in menus, just prey it accepts it.
large driftings, this mostly issue for people hovering over moving water and lower distances off the surface but it can happen to anyone, specially issue at lower light when the vision system i guess gets confused more easily, not huge issue but its potentially a hazard as it can fly into people and vehcials while drifting sideways..
battery life, ok, this is subjective, but battery life is too shortfor me, 16 minutes rated runtime... realistically between 12-14 minutes...you will be surprised how fast you eat that all up.. definatly could benefit from a better/extended battery
range, mostly down to poor use of wifi signals 2.4 and 5ghz bands.. but the spark loves to channel hope and band hop, this cn cause disconnections, lag, interuptions and just straight up loss of range. as my drunken GF best put it: "how far would you fly your wifi router out?" when you think of it like that you realize the limitations....and the curious way a drunken mind works problems out...
this isnt a final list of problems..this doesnt mean you will experiance all of them or any of them... but do take note and take care.. the DJI spark is defintly not a polished finished product in its current state, alot of things can be fixed with firmware updated and software updates...
as for people comparing maic pro to spark, dont, its not even in same catagory.. mavic has its share of early issues to that turned me off, until i could afford drones again.
Mavic is for serious Prosumers. the Spark is more for entry market.. that being said, Spark should have had Occusync option for the flymore combo. maybe Spark 2 will feture it..
