Dean cohen
Flight distance : 131060 ft
Hi guys I found the fix and mine is now working and I'm able to download and view maps from around the world.. although dji have said it's not compatible with spark as it's not been tested, so far now I've fixed the map problem it seem to be working as it should , but so far only if you have the remote. The crystalsky to the spark is a different thing as can't seem to get the two to work .
If you are having the same , you will need to start from scratch. I think the maps problem is caused by them being set up in China which is why I could not find the rest of the world . The way you will need to do it is by going to settings on the crystalsky and select backup reset . Then take back to factory settings. This will delete all on it and you will end up with a clean install . At this point go to go4 app and click on the top right corner and select offline maps . If you have done reset you will now be able to select the country and its areas from the drop down box. They should all be available now and your not just limited to China areas. |
