New firmware bricks battery, anything to do with the falling cases?
1057 9 2017-7-28
Phuong Do
Flight distance : 29800 ft
Vietnam
Hi guys,
We were all aware of the infamous falling cases of Spark before the update on 26/7.
There were many theories so far, however, the most agreeable seems to be that there is some issue with batteries. And coincidently that the new firmware update did have something to do with the battery, and also coincident enough that the firmware did brick some batteries...
My question is, would the falling issue is really because of the battery, and the new firmware did intentionally brick those bad quality batteries to prevent users from using and falling? Because the brick is random with some batteries only, just like the falling is just randoml with some Sparks only.
2017-7-28
$gambino$
Flight distance : 1563980 ft
Idk i know the battery part of the upgrade did take awhile stuck at 97% maybe people are pulling them off to early thinking fw update got borked but really it was fine. I know i almost did. Cant really say its related to the sparks dying midair me thinks its not being latched all the way!
2017-7-28
Phuong Do
Vietnam
$gambino$ Posted at 2017-7-28 19:33
I highly doubt about users taking battery at 97%. Everybody would know 97% means not yet finish, and nobody would recklessly take the battery out at 97%. Not to mention if they want to restart, can just push on the power button rather than take out the batteryy. I think that is not quite logic.
About the latch, many already confirmed they did check the latch carefully, and some cases the battery latches still tight after the fall.
2017-7-28
$gambino$
Mine stayed on 97% for about 5 to 6 minutes to a newb they might think that it was a glitch or it failed and try to restart fw
2017-7-28
$gambino$
No one said u had to take out battery to restart tge fw upgrade.....sheesh u and all your "theorys"
2017-7-28
Supong
Thailand
No issue at all, updated 9 pieces.
2017-7-28
$gambino$
I guess we wont ever know until dji starts digging into things.
2017-7-28
Phuong Do
Vietnam
$gambino$ Posted at 2017-7-28 19:46
Well, we are dicussing here, so,  If you think my explanation is not reasonable and have better idea you can always propose rather than "sheesh" me (Although I does not know what "sheesh" mean either)
Maybe it is language matter, you said in you first reply "pulling them off ", so I thought you meant pull off the battery.
2017-7-28
fans5d9349b7
I refreshed the firmware with my previously faulty battery (fell from the sky) and it updated smoothly and still works. I don't know how confident I am that it won't fail again at some point. Only time will tell.
2017-7-28
Hathdert
Flight distance : 459094 ft
Brazil
fans5d9349b7 Posted at 2017-7-28 21:08
Can you please provide the flight log of your fell of sky Spark on phantom help site?
2017-7-29
