RTH Flight Speed
716 9 2017-7-29
Benjeeeman
Flight distance : 17402 ft
I was flying my drone and my phone had died and i could not see through the camera. It was pretty frightneing because i was really far out, so i hit the RTH button but the drone was returing at a speed of 5km/h is there anyway i can make it faster.
2017-7-29
gnirtS
Flight distance : 2993497 ft
Cayman Islands
If its only returning at 5km/h then its going into a big headwind.
You always need to check the wind - smart RTH will end up dropping way short if theres a strong headwind coming back.
2017-7-29
CharlieFliesDro
Flight distance : 36148 ft
again my hard and fast rule Not to fly with less then 20%  just can't predict what wind is doing 100-400ft up
....C
2017-7-29
Benjeeeman
CharlieFliesDro Posted at 2017-7-29 19:34
....C
i was not flying with fast wind speeds i was only at 45m height and i had 75% battery
2017-7-30
hallmark007
Flight distance : 6794423 ft
Benjeeeman Posted at 2017-7-30 00:03
If there was no wind then your AC should move much quicker than 5kph , so either you didn't realise how windy it was up there or you have a problem, test it at a distance you can see your Mavic , it might give you some answers.
2017-7-30
Bekaru Tree
Flight distance : 15513100 ft
South Africa
You can make it go faster by switching to sport mode and pushing full forward stick - you have to ENABLE MULTIPLE FLIGHT MODE in the settings then you can use the button on right side of controller - push button up to engage sport mode. but beware because left and right movements become very sharp and makes controling it a bit tricky esp if you have less practice in sport mode. what are yr battery warning limits set at
2017-7-30
gnirtS
Cayman Islands
How do you know that?
Winds aloft are usually a lot higher than surface winds.
Upload the txt log to airdata.com and it'll calculate the wind speeds.
2017-7-30
Bekaru Tree
South Africa
You are not perhaps flying in beginner mode or tripod mode?
2017-7-30
DJI Susan
In the RTH, the Mavic will go up at the speed of 5m/s and descend at the speed of 3m/s. The horizontal speed is 10m/s. The speed will change in strong wind. And you can speed up via sticks. Please take care and make sure there is enough battery when fly in wind.
2017-7-31
gnirtS
Cayman Islands
Quite possible he's confusing km/h for m/sec then?
2017-7-31
