DroneFlying
Flight distance : 10774613 ft
Yep, that worked. This looks very much like a case of taking off from a geomagnetically distorted site, which is usually because there's some metal nearby that affects the compass.
Notice how in the graph below that yaw (what the Mavic think its heading is / should be in yellow) and magYaw (the heading detected by the compass in red) were closely aligned until you took off (around 0 on the horizontal axis), at which point magYaw began bouncing around and deviated a bit more from yaw, which in turn triggered the errors you saw. That happens because the compass readings fluctuate as it begins to get clear of whatever source of interference had influenced it before.
The variation was large enough at around 12.5 seconds into the flight to trigger a YAW_ERROR_LARGE (shown by the blue shading), and then about a second later it went into ATTI mode (the purple shading). And since GPS is disabled / ignored in ATTI mode, the Mavic reverted to the behavior I mentioned earlier where it assumes that it's in an NFZ when it has no GPS (e.g., indoors), which is why you got the NFZ warning message.
The bottom line is that this is all normal behavior, so it should fine to fly in the future as long as you take off from a location where there's no magnetic interference. |
