nicoleto
Colombia
Hello every one.
I need some coments or suggestions from the I1 experts. I’m having a very odd problem with my I1. First of all I must say I only have had 3 flights whith the Inspire and it flies very smooth and stable. It holds its position very well either with GPS or the Sonar/Camera sensors.
The problem I’m experiencing relates to the compass calibration. The compass procedure goes as indicated and after calibration I get the safe to fly with GPS signal. However, when I’m flying, I start getting the “compass error calibration is needed” messages. The difference here is that if I fly with the I1's nose pointing to the same direction, (lets say for the sake of this example, pointing west) as the one used when I started the compass calibration procedure, I get green lights and “safe to fly with GPS” message. If I start turning to any direction and pass 90 degrees from the start point I get the red light and the “compass calibration needed” message. The GPS signal seems to be ok and the I1 keeps its position no matter If the compass error appears or not.
As a second test I redid the compass calibration but this time I started the calibration pointing to the opposite direction, lets say East. This time, the same problem ocurred. If pointing East and not passing 90 degrees from the point of origin, I got the green light and "safe to fly with GPS" messages but passing 90 degrees, I started getting the compass error. By looking at the screen I could see that the messages constantly fluctuated green to red.
Any comments are very welcome
BTW I'm using firmware 0.17
Cheers to all
Nick
