How accurate is when your Spark returning to Home Point?
2477 9 2017-8-2
Thenhan
Flight distance : 275571 ft
Hello,
My Spark does not return to its Home Point, a few inches away.  Here is the video:
2017-8-2
ImHereToCrash
Flight distance : 5381368 ft
it only returns home to exact point a set min distance.. i think is 30 meters away. ..?  i'm not sure i forget but you have to be further away..   otherwise it just autolands...
also i personally vouch against using standard RTH... im all for smart RTH, but standard RTH is about as dumb as a brick..
2017-8-2
eylneb
Flight distance : 122477 ft
Malaysia
in order for Precision Landing to work you have to fly up to about 7/8 meters and hover for awhile for the VPS to "capture" the ground
also if you initiate RTH within 20\30m it will land at current location.. unless you enabled RTH at current altitude. (stated in manual)
2017-8-2
Thenhan
eylneb Posted at 2017-8-2 18:12
https://www.youtube.com/watch?v=moRMp1ydP9M
Thanks a lot.  I'll try to fly higher next time to check my Spark's PL.
2017-8-2
eylneb
Malaysia
Thenhan Posted at 2017-8-2 19:17
yup... after you take off.. do nothing but fly up higher...
2017-8-2
Thenhan
eylneb Posted at 2017-8-2 19:21
What screen recording app are you using?  Please let me know.
2017-8-2
eylneb
Malaysia
Thenhan Posted at 2017-8-2 19:27
im sorry that vid isn't mine.. but i've record with ios11 public beta screen record before..
2017-8-2
ImHereToCrash
if you are using android the best recording app is "DU recorder"
if you are using iOS the best recording method is using ios 11 public beta
2017-8-2
Thenhan
ImHereToCrash Posted at 2017-8-2 19:59
Thanks ImHereToCrash and eylneb.
2017-8-2
ImHereToCrash
Thenhan Posted at 2017-8-2 20:08
no problem!
2017-8-2
