Quadrocopter
Flight distance : 250125 ft
My first thought would be to narrow the issue down to either the controller, or the tablet. The copter isn't the issue here since you'll at least get a "No Signal" error at the top if it isn't connected to the copter. Try to connect up with another Android or even a iOS device if you can borrow one. Also, try going into developer settings within the shield and In your device and revoking USB debugging authorization.
Go to settings.
Select developer options.
Tap Revoke USB debugging authorization.
Press Ok.
Now try connecting up to the controller, it should give you a warning asking if this computer is okay to connect to, click the box "Always allow". Then the DJIGo4 app should open automatically or prompt you to open it.
Good luck,
Chris |
