kruggel
Well heres one for you,
after two days of work i figured it out, how it does work and how it works through lightbridge. But! It has a major downside!
To get it to work, you would first of all, need to calibrate all the necessarry channels in lightbridge it self. hook LB to your PC and hit calibration, make sure you have all the 12 channels available as a moving slider.
Then you want to hook all the cabels to the A2 form X3 all the way up to F4. And there you have it, thats the downside all the ports are used. And another downside ist that, if your main power supply is dead the parachute also is.
But anyways, all you need to do now is, hook up A2 to the assistant software and calibrate the sticks again.
Then and that is the tricky part, assign channels to D2 and D3. And here is the weired thing or lets say the most confusing, LB channels are not A2 channels!!!!!!!
D2 with my radio (14sg) is set to CH15 and D3 to CH12, the corrospinding channels in the 14SG are CH12 and CH11!
So this is how it works as a single operator setup, but, it's not really suitable for all the other channels you would need for gimbal control and so on....
Hope that helps for now, i'll further investigate. |
