szh
Flight distance : 252139 ft
Today while flying and recording video, the gimbal seemed to suddenly reset. You can see how it happened in the cached video below:
https://www.dropbox.com/s/lsi8l6 ... 5_19_19_49.mp4?dl=0 (jump to 0:40)
The video on the SD card ends at the point of the error, and has an incorrect date from 2013. The DJI Go app showed no warning or errors.
The problem repeated later 3 more times (during subsequent flights). Later I noticed that it always happened after about 41 seconds into recording, and that the recorded files are all 325 MB in size (4K 30fps), except one which is 330 MB.
Has anyone experienced anything similar? Does this indicate a fault with the drone? Most importantly, is it safe to fly?
I did ask DJI support about this, but I do not expect them to respond before next week, and I was hoping to get more information here.
Here are the logs from DJI Go: http://app.airdata.com/main?share=ReHpyr
I downloaded the .DAT files from the device using DJI Assistant, and tried to look at it, but I do not have the experience to be able to interpret it. I did notice a strange spike in many (but not all) measurements. However, I cannot tell if this spike is at the same time where the problem occurred. Here's a screenshot (below, see around time 220). Such a spike is visible in many other measurements, including air pressure, ultrasonic height, GPS level, etc.
