mhoppes
Flight distance : 141302 ft
I really like my + controller... it's bright, it's integrated, it's fast to setup.
But... there are times where an outboard computer (iPad) would be very helpful with the larger screen.
Is there any reason I can't run both a + and standard controller and just bind them back and forth depending on what I'm doing? I assume the only main thing I'd need to be mindful of is firmware versions matching between everything?
What happens if a maximum altitude (or other setting) is set on controller A, then controller B is bound? Do the settings on the iPad software upload into the drone? Or does the software read the settings from the Drone that were set by Controller A?
