hallmark007
Flight distance : 9827923 ft
Your Aircraft picked up strong magnetic interference effecting your compass causing conflict with Imu heading and gps.
Aircraft went into Atti mode , you handled it very well you had plenty of altitude and your Aircraft was in sight
The Speed error is because the spark calculates speed by looking at the distance moved each 1/10th of a second. It's done it's arithmetic worked out that the speed it's calculated is wrong, probably because the GPS position it's used is incorrect.
Yaw errors are similar.
Because you managed to keep some control of aircraft you eventually regained gps and you were back in control and your spark is fine.
Log doesn't tell how you picked up compass problem , did you take off near concrete with reinforced steel or near metal objects this is the most common place to pick up compass problems, you were flying over some trees when compass went bad so this is unlikely, other cause is bad calibration, did you calibrate and when and where.? |
