dm.booth.hotmai
Flight distance : 153760 ft
So I received my Inspire yestarday, downloaded the firmware from DJI, copied accross to the sd card, installed into the camera, did the inspire first then the controller
Put it back into travel mode and back in the case
Today set everything up would not come out of travel mode, firmware deials below
With no camera attached, using the app nothing happens, using the switch 4 times I get a solid blue light on the inspire still nothing happens.
Balencing the inspire between 2 chairs with the camera attached, flick the switch 4 times nothing happens not even the blue light just a flashing green gps light, as you can see from the below screen shot the camera is working great, just cant get it out of travel mode
HELP
