5.8GHz to 2.4GHz switch does not work with new version
1143 3 2017-8-17
Koppo
Flight distance : 191726 ft
Hi,
before all the updates etc I could switch from 5.8 to 2.4 by connecting to RC via WiFi, switching to 2.4 and then connecting the OTG cable when the screen turned black and white.
It then automatically connected and I could fly on 2.4, which gave me much better range and image quality during transmission.
Now, when it's black and white and I plug in the OTG nothing happens. I have to restart the APP and it is on 5.8 again.
Is there a workaround?
2017-8-17
Monochrome
Flight distance : 12710 ft
2.4 works for me just fine with otg.
2017-8-18
DJI Diana
Flight distance : 2408 ft
What mobile device are you using? Can you see the 2.4 G wifi in the wifi list of your phone? Have you tried to reset the WiFi? It is not recommended to use the OTG cable since it hasn't been fully tested.
2017-8-18
Koppo
DJI Diana Posted at 2017-8-18 23:39
Hi Diana,
I am using Samsung S8. I can use 2.4 when using WiFi only. Unfortunately, using WiFi only gives me hardly 300-400m range. With the OTG on 2.4GHz I was able to get 1.4km range.
2017-8-28
