DJI Diana
Flight distance : 2408 ft
Dougb 9 Posted at 2017-8-20 01:48
What a disappointment! Received my new Mavic on Friday 18 Aug 17, charged the batteries, switched it on and all seemed to be working correctly including the camera. Did all the recommended firmware upgrades on both AC and Controller to Ver 03.0900 from 03.0800. Calibrated the compass and IMU, start AC for first flight but now the camera doesn't work. Message on the screen "No Image Transmission Signal" Tried to revert to the earlier version of software but update failed at 53 percent with the message "Update failed Undefined 0X020104" Tried to re-install ver 0900 but it also failed.
Overall Status: Air Encoder Error (0x800000) Restart Aircraft - Contact DJI Support if it persists after restart.
Sorry to read on it, you may need to send it in for diagnosis, please contact the Support to start a case. They will tell you how to send it in. If you purchased it from a reseller, please contact the reseller, see if they can replace it for you. http://www.dji.com/support |
