MCU Error?
2988 5 2015-3-29
csiami
Flight distance : 23711 ft
Flying my P2V+ V2 today. suddenly I got an MCU Error on my screen. All lights went red. I landed. Powered off restarted. Flew the rest of the battery cycle no problem. Can anyone explain an MCU error?
2015-3-29
Northofthe49th
Please plug your Phantom into the Phantom Assistant and tell us what you see, at this point, too generic to guess but we could guess and send you on a wild goose chase in the process.
Please also check the manual as there are several references to the light sequences that may you give you a better indication first hand of what is going on.
Please let us know what you find.
2015-3-29
nrgwise
As Mr. North said, we need more information to help effectively.  Always, the more information, the better.
2015-3-29
csiami
I connected to the assistant.  Everything looks good.  I did an Advanced Calibration.  Got the green light.  I'l  look in the Manual,  I tried to Google what an MCU was and wasn't successful.
2015-3-29
Northofthe49th
csiami Posted at 2015-3-30 10:32
I connected to the assistant.  Everything looks good.  I did an Advanced Calibration.  Got the green ...
MCU = Master Control Unit = Your Phantom's Brain has an issue, intermittent or otherwise and needs to be fixed...check out...
Also check this out...http://forum.dji.com/forum.php?m ... ght=mcu&lang=en
Are you using Android?
2015-3-29
csiami
Yes was using Ken's app on an android tablet.  I'll pull the cover and inspect for damage.  I did have a crash about ten flights ago.
2015-3-29
