Ex Machina
Flight distance : 1806362 ft
Ferks Posted at 2017-8-22 11:41
I've used the app a couple of times with no issues, however I don't believe DJI even supports it even though it's their software, I believe it's because GS Pro does not create flight records, I believe GS Pro looks at the DJI Go 4 settings and uses them, not 100% sure on the last one.
Looks like it was updated this month with several in-app purchase options and enhancements:
What's New in Version 1.6.0
1. New: Support for M200/P4A
2. New: Support for KML/SHP/KMZ file import, view, and creating flight missions accordingly
3. New: Save the current mission’s parameter as Default, so that newly created mission will follow the same parameter
4. New: Support Poly No Fly Zone
5. New: Add option to always display WGS84 coordinates, even in non-WGS84 environment
6. Enhancement: Max Flight Height extend to 500M
7. Enhancement: Flight Speed now could set down to 1 m/s
8. Enhancement: More information in the parameter info panel.
9. Enhancement: When setting camera pitch in 3DMap, the flight route will shift accordingly to capture the target area
10. Fix: No video streaming when using Zenmuse Z3 camera |
