Spark flew away while following me
12Next >
3571 44 2017-8-24
ocean224
While commanding my Spark under gesture contol yesterday, I was having it follow me for quite a while when all of a sudden it took off vertically and got eaten by a tree. I really don't know if I will be able to recover it. Question is: What would make it do such a thing? If I can't recover it, I will be out of luck since I was not using the RC and there is no data recorded.
2017-8-24
Dirk52
Flight distance : 232995 ft
Sounds like a RtH bug. (normally in gesture control only there is no rth)
Maybe the one with the same problem will say something about it here. There was a thread about it a few weeks ago.
2017-8-24
Charles Adams
Flight distance : 3821312 ft
Not that this helps you, but I never perform gesture controls without a means of remote controlling it on hand (which I agree defeats the purpose of the gesture control).  This is because I don't yet trust the craft to behave, your case being a prime example.
Is your spark irretrievable? Too high up in the tree to safely retrieve?
DJI Moderators will have to address the possibilities of exercising any warranty.  Can you get a picture of the drone, using a ground based camera?
An important thing to consider:  Why did this happen?  Without logs, it's challenging to make that determination.  Were you flying in an environment with a lot of buildings or structures?
2017-8-24
S-e-ven
Flight distance : 5922034 ft
Thailand
https://forum.dji.com/thread-106790-1-1.html
2017-8-24
ix3lplix
Flight distance : 145846 ft
You mentioned that it was following you for quite a while. How far were you from your original launch point?
I think I remember reading that the aircraft is still bound to the same home point that it recorded when you first launched. If you traveled far enough from that location without resetting a new home point, this could have triggered a RTH. Maybe your RTH altitude was not set high enough to make it over the trees which is why it hit them on the way back.
2017-8-24
ocean224
Charles Adams Posted at 2017-8-24 06:40
Yes, it's pretty high up. Maybe 35-40 feet. I don't have the equipment to take a photo. Lesson learned, gesture control isn't what it's cracked up to be. And yes, it happened in an urban area. 2 story buildings and trees. If we get some wind, it will probably come down. It looks like it is just barely caught on the branch. Im going to build a 40' pole out of 1/2" conduit when I get home and try to coax it loose. I  even purchased DJI care refresh, but I think I need a body to make a claim.
2017-8-24
Charles Adams
ix3lplix Posted at 2017-8-24 06:49
The way the issue was described, I interpreted that the spark flew up into the tree.  I'm envisioning that this pilot started in a location using gesture control, and then walked far enough AND used enough battery to have required RTH...  at which time the drone elevates into the tree.
If I'm right, this was absolutely normal and expected drone behavior (no offense to the pilot intended).
2017-8-24
Oracle Miata
Flight distance : 3759829 ft
The above post is correct.  If you traveled maybe 50 meters from where you launched you will have issues.
2017-8-24
hallmark007
Flight distance : 10017858 ft
ocean224 Posted at 2017-8-24 06:50
You will need AC to make a refresh claim , I suggest you try get some help getting it down, there will be record in your spark as to what happened.
Good luck
2017-8-24
ocean224
Agreed, pilot error. I believe I was low on power and triggered RTH. This may prove to be an expensive lesson.
2017-8-24
Charles Adams
ocean224 Posted at 2017-8-24 07:34
I hope the pilot can retrieve it.  There have been complaints by other individuals where the pilot was really being ignorant.  I don't think THIS was such a case.  If this happened as I envision, this is a fairly innocent (hopefully not costly) flight mistake.
2017-8-24
HomePoint
Flight distance : 776007 ft
If you know which tree it is in, then at whatever cost I am sure you should be able to recover it, or is it in a group of trees that are impossible to know where it is?
2017-8-24
Sparky_17
Flight distance : 62349 ft
Sounds like the RTH was triggered, possibly due to battery reaching 30%.
2017-8-24
Charles Adams
IF this is in fact what happened, I'm wondering if there shouldn't be an enhancement request for this behavior.
For everyone's critique:
If in gesture mode, the software could/should assume that it is within a short distance of the "home point", and if RTH is engaged, should land in location.  This is because "gesture mode" implies that there is close proximity to the pilot, who is piloting the craft with physical body gestures.  In this use case, "home point" will always be in close proximity to the craft.  Even if the user walks some distance away, and the craft follows, it seems to be a safe assumption for the software that "home point" is quite local.
Just some thoughts...  open to critique and criticism.
2017-8-24
ocean224
HomePoint Posted at 2017-8-24 07:53
I can see it. Gonna make a drone retriever when I get home.
2017-8-24
Flying Wolf_NOL
Flight distance : 345827 ft
Charles Adams Posted at 2017-8-24 08:09
I agree with this totally.  I always set my RTH altitude at the max 120 meters (so if it has to return home, it will be well above any obstructions). However, in gesture mode, it 'should' always be close to the user. Just have it land (or hover at the last altitude) landing could be an issue if it is following you over a foot bridge, for example,  or through water.. I know those are unlikely scenarios, just trying to think through any possible issues.
I've only used gesture mode once to kind of 'try it out'.   I actually wish that it would have been left off of the craft. It gives it a 'toyish' reputation, when it's anything but a toy. It has also caused more than one customer to have a very bad experience which (if it were me) would cause me to think long and hard before purchasing another DJI product.
In any case, best of luck to the OP. I hope you get your spark back.  Having crashed on UAV myself, I know that feeling one gets in the pit of your stomach. It isn't pleasant.
2017-8-24
ocean224
Flying Wolf_NOL Posted at 2017-8-24 08:33
Yes, i think it should just hover. In any case I was just playing with gesture mode and I'm through with it now. It is toyish and not really useful as far as I can see, although someone may have a use for it.
I think I have a good chance to recover the Spark.
Thanks for all the comments.
2017-8-24
Charles Adams
I think that there are valid use cases for gesture control, just none that I heavily rely on.  I know the intent is for "ease of use" and a whole new world of "selfies".  I find there to be practical application in launching and landing in difficult terrain (say a boat, or up in my mountain property where there isn't a lot of flat ground).  I'd like to see palm launch be 100% reliable, for these corner cases.
2017-8-24
Montfrooij
Flight distance : 2560453 ft
Indeed RTH and, or in combination with, the gesture modes seem to cause many accidents.
I must say I like the idea of an algorithm flying perfectly around my subject, but have yet to find out if it works for me.
2017-8-24
ocean224
Conduit drone retriever........fail. Too heavy. Called an arborist to climb the tree.
2017-8-24
Jeff7577
Flight distance : 1916821 ft
There is no RTH when in gesture mode with no phone or RC connected, there is no home point.
2017-8-24
Jeff7577
Yeah, there is no reason for it to ever RTH in gesture. If it goes into low battery it just lands.
2017-8-24
Charles Adams
Jeff7577 Posted at 2017-8-24 16:24
You certain?  It may be worth a test (a reason for me to go fly).  I know that the manual does cover use cases involving both gesture mode and phone, so I know that a phone can play a role when using gesture mode (and in fact improves one of the features).  I may go for a walk and talk my friend sparky.
2017-8-24
DJI Elektra
China
Flight performance can be affected by environment.
Here are some advice
1.Please fly in a wide place and pay attention to things like,plant, high voltage lines,metal. Those things will let the compass go wrong.
2.Not to wear dark clothes, or clothes may absorb infrared light.
3.The Gesture mode may not perform well when the aircraft flies over surfaces without texture, in extremely bright surfaces, or in heavy winds.
2017-8-25
ocean224
DJI Elektra Posted at 2017-8-25 02:42
Elektra,
Can you please clarify the RTH issue? Is there RTH in gesture mode or not?
Thank you
2017-8-25
fans99d24711
Maybe not. Mine took a pretty nasty fall and no damage other than a couple of props. They are pretty tough.
2017-8-25
FatherXmas
Flight distance : 4058619 ft
ocean224 Posted at 2017-8-24 15:10
Or a tree climbing neighbor kid.
2017-8-25
Spaners
Flight distance : 1542 ft
In the DJI video I watched they did recommend having the drone connected to a mobile device when using gesture mode. Not that this would excuse what happened on DJI,s part.
If it is the case that it went into a RTH failsafe mode because of the distance travelled from a home point or a low battery warning then this action should have been noted in the manual.
My boss would sac me if we sent out a machine with this many inconsistancys and ommisions
2017-8-25
Spaners
I really must read back my posts before I post them, my spelling is just sinful
2017-8-25
LouisP
Flight distance : 41952 ft
I once had a Parrot drone stuck up high in a tree for three days.  I wound up paying a guy with a buckt truck $50 to get it for me.  Might be worth paying for someone so that you can use the DJI refresh.
2017-8-25
ocean224
Well, I coaxed it down. It's now off to be "refreshed" It landed onto concrete sidewalk. The gimbal is badly damaged. At least I have the "body" to return to DJI.
2017-8-26
Indi91
Flight distance : 103973 ft
Malaysia
On side note, please do keep watch on the indicator lights, if it blinking red, bring it down immediately.
2017-8-26
Charles Adams
ocean224 Posted at 2017-8-26 03:46
Congrats!  Hope this doesn't discourage you from flying.
2017-8-26
ocean224
Charles Adams Posted at 2017-8-26 04:02
Heck no! Just a minor setback with the Spark. I have other stuff to fly until I get it back. There is soooooo much to learn.
Thanx
2017-8-26
ocean224
Indi91 Posted at 2017-8-26 04:02
Will do! But, DJI electra has yet to respond to the RTH thing. Is there RTH or isn't there RTH when flying in gesture mode with no RC or device?  It will probably take me at least a month to get my Spark back to test this.
2017-8-26
ocean224
LouisP Posted at 2017-8-25 14:58
In this part of the world they want $270.00 for a bucket truck rescue.
2017-8-26
Charles Adams
In another thread, I posted results of my RTH tests.  One of those tests was specific to THIS use case.  Not using any RC or phone, I flew my craft using only gestures.  I palm launched, I made the craft go away and follow, and then I walked some distance away.  I let the batteries run down until the RTH functionality was triggered.  The craft did in fact ascend to RTH height, did in fact fly back to original launch location, and descend there.
Whether or not this is intended, this is the current behavior.  I would prefer that this behavior be changed such that craft in gesture mode always assumes it is within close proximity of launch point, regardless of distance traveled, and that it descend in place.
2017-8-26
ocean224
Charles Adams Posted at 2017-8-26 06:52
Thanks Charles, I wonder why DJI is so silent on this? This is what must have happened to me to the best of my recollection of events leading up to my tree grab.
2017-8-26
Charles Adams
ocean224 Posted at 2017-8-26 07:17
To be fair, I don't think anybody has directly asked DJI (or moderators) about their knowledge and expertise for this use case.  Let's rectify that:
DJI Moderators:  We have reviewed and tested a use case involving flying with just gestures (no RC and no phone), and we have encountered some concerning behavior.  I think it would be better if this behavior were updated (described elsewhere in this conversation).  But there are questions:
What role does gps and compass have on the craft when flying in gesture mode?  Is it possible that gps and compass disruptions will impact the flight?
2017-8-26
ocean224
Charles Adams Posted at 2017-8-26 07:21
+1 And I did ask DJI Elektra to respond to thid issue.
2017-8-26
12Next >
